So I got a hi coolant temp warning even though temp gage never went past next line above middle line. Pulled over and just before turning car off I got an oil pressure warning.
Opened the hood and found that the lower hose from reservoir tank popped off. I had just replaced radiator about 2 weeks ago, so I thought that combined w/ 114 degree weather, it got hot enough that it popped off hose because I forgot to tighten it down.
So after refilling reservoir and running a/c on HI for about 1 min, bubbles come up. A few seconds later after an increase in bubbling, it vomits the coolant out the top. When I don't run the heater and I idle engine it takes about 1 min longer before it bubbles and a few seconds later it vomits again. Got towed and tried it again about an hour later and it did the same thing.
Ive refilled coolant a number of times and I've never seen water come out like that from coolant tank during purging process.
I checked oil dipstick and oil cap and oil seems fine. Car turns on, idles fine, and I don't hear any odd noises other than more burping noises from exhaust.
I've changed the coolant before and I haven't ever seen car do this before.
Is this normal? Any suggestions?
