CTS Turbo Muffler Delete - A3, S3 Gen. 3 - 1.8 TFSI & 2.0 TFSI
CTS Turbo is proud to release our high flow Turbo Muffler delete for 1.8T and 2.0T engines equipped with IHI Turbochargers (see application guide below). The CTS Turbo Muffler delete is a one piece design CNC constructed from T6 6061 aircraft grade aluminum and hard anodized to reduce wear. Our Turbo Muffler delete replaces the restrictive, power robbing OEM Turbo Muffler, which is designed to reduce turbocharger harmonic noise. Our kit installs in 30 minutes with hand tools, seals using the included O-ring seal with standard hand tools and looks stealthy like the OEM unit. For those of you that want optimal power and boost response the CTS Turbo Muffler delete is your answer.
Application Guide:
Audi - S1 EA888 Gen 3 - 2.0 TFSI
Audi - A3 & S3 (MK3) - EA888 Gen 3 - 1.8 TFSI and 2.0 TFSI
Audi - A4 / Allroad (B8 & B8.5) - EA888 Gen 2 & 3 - 2.0 TFSI
Audi - A5 (B8 & B8.5) - EA888 Gen 2 & 3 - 2.0 TFSI
Audi - A6 (C6 & C7) - EA888 Gen 2 - 2.0 TFSI
Audi - Q5 - EA888 Gen 2 & 3 - 2.0 TFSI
Audi - TT / TTS (MK3) - EA888 Gen 3 - and 2.0 TFSI
VW - Golf / GTI / R (MK7) - EA888 Gen 3 - 1.8 TSI and 2.0 TSI
Price: $129.99 Shipped - CLICK HERE TO ORDER
CTS Turbo Audi A3 8P FSI Catch Can Kit
CTS Turbo is proud to offer the premier catch can solution for the Golf R, Audi A3/S3 and Audi TT-S with 2.0T FSI motor.
The oil catch can is used prevent oil vapors entering the intake manifold and clogging up the intake valves on direct-injection motors. Oil deposits on intake manifold and valves cause reduced performance, bad fuel mileage and could damage the fragile intake flaps and motor.
Kit Includes:
CTS Turbo billet aluminum valve cover breather CNC machined for beautiful finish
CTS Turbo Billet aluminum catch can with billet oil-level dipstick
-10 AN Black-Series braided hoses
Oil catch can mounting bracket
Modular intake manifold plug
Hose-Wrangler clamp
Kit Fits:
2012+ MK6 Volkswagen Golf R North America
2012+ MK6 Volkswagen Golf R R.O.W.
2007+ MK2 Audi TT-S
2006-2008 Audi A3 FSI (pre-facelift)
The mounting solution is available for left-hand side of engine bay for North American cars or right-hand side of engine bay for vehicles with charcoal canister. Please note this kit does not fit with stock engine cover.
NOTE: right-hand side mounting is only compatible with CTS Turbo or Carbonio intake systems.
All installation hardware is included.
Keep your Golf R, Audi A3/S3 and Audi TT-S with 2.0T FSI motor running smooth, clean and enjoy the peace of mind that comes with knowing that the PCV system on your car is now free of issues.
Price: $349.99 SHIPPED - CLICK HERE TO ORDER
CTS Turbo 8V S3 Catch Can Kit
CTS Turbo is proud to offer the premier catch can solution for the MK7 Golf R & 8V S3. The oil catch can is used prevent oil vapors entering the intake manifold and clogging up the intake valves on direct-injection motors. Oil deposits on intake manifold and valves reduce performance, and cause bad fuel mileage. Keep your engine clean, running smoothly, and enjoy the peace of mind that comes with knowing that the PCV system on your car is now free of issues.
Kit Includes:
- CTS Turbo Billet aluminum valve cover breather CNC machined from a single block of T6061 aircraft grade aluminum.
- CTS Washer fluid reservoir relocation neck
- CTS Turbo Billet aluminum catch can with billet oil-level dipstick
- 10 AN Black-Series braided hoses
- Oil catch can mounting bracket
- Stainless Hardware
- Hose-Wrangler clamp
Kit Fits:
- 2015+ MK7 Golf R Black Engine Cover
- 2015+ Audi 8V S3
NOTE: Check your engine mount bolt, it must have a stud for catch can to be mounted to. If you have a flat bolt, you must purchase this double-ended stud: N91029602
PRICE: $449.99 Shipped - CLICK HERE TO ORDER
CTS Audi A3, S3, Intake (MKIII 2015+)
At CTS Turbo we are proud to announce our new air intake system for the Audi S3/A3 is ready!
The OEM air scoop works in conjunction with our sealed airbox to seamlessly force cold air into our air intake system. Air then flows through our 3.5" high flow air filter, which utilizes an inverted cone design for maximum engine breathing. Our 3.5" CNC mandrel bent aluminum intake pipe allows for smooth entry of cold air directly into the the engine, minimizing turbulence from unnecessary connections. All of the components included in the CTS air intake system work flawlessly together to provide increased horsepower and torque throughout the entire power band and an aggressive race inspired sound.
NOTE: If you have Audi S3 you should not require breather adapter and filter. Please confirm on vehicle before ordering.
Peak power gains range from 10-15HP on an otherwise stock vehicle. We recommend disabling your Soundaktor (noise amplifier) to fully enjoy the true sound of your motor and remove excessive drone caused by the device.
Product Details:
- Mandrel bent large bore 3.5" aluminum piping with black powder coating
- Coveted Laser etched //CTS Turbo logo
- 3.5" Reusable air filter with inverted cone design
- 4 Ply silicon connectors with stainless steel clamps
- Sealed air box
- Bracketry to prevent rattling under engine torquing
- Billet SAI breather adapter and filter (Optional in drop down menu)
PRICE: $379.99 SHIPPED - CLICK HERE TO ORDER
CTS Turbo MK7 Golf R/8V Audi S3 Downpipe
We are proud to release the new CTS Turbo 3.5" Stainless Steel downpipe for the MK7 Golf R/8V Audi S3. Unfortunately, the factory downpipe that comes as standard equipment in your car was designed for anything but performance. The factory downpipe severely restricts exhaust flow and therefore has adverse effects on horsepower, especially once your car is "chipped". The CTS Turbo downpipe will allow for your exhaust gases to flow smoothly, freeing up the additional ponies that you want, all while look amazing. Highlights of our downpipe include CNC machined turbine discharge (downpipe) flange, mandrel bent 3" stainless steel tubing, modular design making installation of a catalytic converter simple and straight forward, smooth transitions allowing for optimal exhaust gas flow.
Are you worried about emissions and inspections? Don't worry, our optional catalytic converter from Magnaflow should satisfy prying eyes. Precision fabrication, unparalleled quality and and great price point all make the CTS Turbo MK7 Golf R/8V Audi S3 Downpipe a must have for any VW/Audi enthusiast that values performance and their pocketbook.
Product Details:
-T304 Seamless Stainless Steel tubing
-T304 Stainless Steel flanges
-100% TIG Welded
-T304 Stainless Steel 02 bung
-Torca Accuseal Stainless Steel Clamps
-Great Sound even with factory exhaust, no drone!!
To ensure the best performance and operation, proper tuning software must be used (Stage 2 software from most large tuning companies is compatible).
CTS Turbo recommends choosing a High Flow Cat for the sake of our environment! Using the optional CEL eliminator greatly reduces the possibility of CEL coming on for cat efficiency code.
PRICE: $599.99 SHIPPED - CLICK HERE TO ORDER
CTS VW MK7/Audi 8V DIRECT FIT (GTI, Golf R, A3, S3)
CTS Turbo core size: 25"x2.25"x16" = 900.00 cubic inches or 14.75L
Stock Golf R core size: 24.25"x1.37"x16.25" = 542.00 cubic inches
Stock GTI core size: 24.25"x1.25"x16.25" = 493.00 cubic inches
High density bar-and-plate core with cast end tanks.
Fully compatible with Adaptive Cruise Control (ACC)
PRICE: $799.99 SHIPPED - CLICK HERE TO ORDER
CTS Turbo MQB High Flow Turbo Inlet Pipe
CTS Turbo is proud to announce our High Flow Turbo Inlet. We are the first manufacturer to offer these; made from mandrel bent aluminum and precision CNC machined flanges. This part is compatible with any MQB vehicle, regardless of engine displacement or factory turbocharger size. It is compatible with any intake system, be it factory stock or aftermarket.
Simple installation takes 10 minutes and can be done using basic hand tools.
Don't let your free flowing intake taper into a small restrictive factory inlet. Upgrade to CTS Turbo High Flow Turbo Inlet and make sure you get the most air flow to your turbo!
Fits the following vehicles:
2015+ VW GTI/Golf/R
2015+ Audi A3/S3
Product features:
High flow mandrel bent piping, CNC machined flanges
Compatible with any intake system, including stock
Durable aluminum construction, will not break like factory plastic part
Black powdercoat finish with laser-etched CTS logo
Simple installation
Faster turbo spool, more air flow, improved turbo sound!
PRICE: $129.99 SHIPPED - CLICK HERE TO ORDER
CTS Boost tap for Gen3 TSI engine (2014+)
The CTS Turbo billet throttle body boost tap is the best way to add a boost/vacuum reference to a Gen3 TSI engine.
No drilling of the manifold. Location for the boost/vacuum reference is right after the throttle body. ECU data is not affected.
Designed and built in Canada from billet 6061-T6 aluminum!
1 vacuum port with 1/4" hose barb fitting
O-Ring for simple install and reliable seal
Straight direct path from intake manifold to boost tap for best performance
Installation is simple, using basic hand tools.
PRICE: $59.99 Shipped - CLICK HERE TO ORDER
