Results 1 to 3 of 3
    Registered User Two Rings THMotorsports's Avatar
    Nov 06 2014
    Chicago
    **THMotorsports** Grams Performance Fuel Injector Kit for your Audi
    The EV14 injector’s superior ball/pintle valves combine with Grams Performance’s precision-modified nozzles allow for consistent performance up to 118 psi, making them suitable for a wide range of applications, yet without exhibiting any of the high-pressure problems often associated with other injectors. The optimized spray pattern also helps improve mixture preparation as well as atomization. Each injector is individually balanced, flow tested and dynamically matched for characterization within one percent of each other. To ensure leak-free operation and optimal performance, each injector is then pressure tested up to 220 psi. The results are unmatched cylinder-to-cylinder consistency, even at low pulse width’s, as well as optimal idle quality, response and performance. Grams Performance Fuel Injectors’ ultra-fast and precise solenoids feature a linear response curve across a wide range of operating conditions and can accurately meter fuel even at the highest pressures and shortest pulse widths.
    Order here:
    https://thmotorsports.com/grams-perf...t/g-67609.aspx
    Or send me a PM or an email: [email protected]
    Nov 06 2014
    Chicago
    All PM's responded to!
    Nov 06 2014
    Chicago
    Bump!
