    Established Member Two Rings keithk831's Avatar
    Nov 07 2014
    United States
    Oil in turbo inlet
    Hi, I have noticed whenever I have removed my turbo inlet hose that there is quite a bit of oil where the (PCV?) hose connects. I've also noticed a little bit of oil inside my N75 sensor when I replaced it, as well as the diverter valve. I know the PCV system is intended to recirculate burned oil gasses back into the system, but this seems like more than it should be ahead of some vital components.
    Is this normal?
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Normal, the PCV system does not remove all the oil mist in the blow-by gases. You need to install a properly filtered catch-can into the PCV line into the intake manifold, and another one in the hose from the PCV to the turbo inlet pipe.
    Veteran Member Four Rings inNout's Avatar
    Jul 22 2009
    IL->WA
    +1 i see it whenever i pull the intake.
    2010 B8 2.0T 6spd K04 + [HPA Motorsport, Rays, APR, Eisenmann, Bastuck, Eurocode, KW, OSIR, StopTech, ArmaSpeed]
    Veteran Member Four Rings Zach L's Avatar
    Feb 24 2010
    Austin, TX
    That's exactly why they make catch-cans. That said, even the best catch-can setups will only filter about 80% of the oil.
    After it goes through the turbo, the oil travels through all the boost piping and then coats the intake valves. To keep 100% of the PCV gases from recirculating, you have to vent it to atmosphere or install a custom, exhaust-routed PCV setup.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Nov 07 2014
    United States
    Thanks everyone!
