    Mar 27 2016
    Scandinavia
    rear suspension help
    just curious if theres supposed to be a gap like(on the height adjuster for the spring) this when I have got the springs on(ive tightened the subframe)
    pictures
    http://imgur.com/a/o1fwM
    maybe it'll stand straight when I get the car on the ground, not really sure(im an amateur)
    thanks in advance
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Do you have matching struts? The spring should be tight in place where you cannot move it with the subframe tight.
    Also make sure your subframe is centered or else you will have a weird offset on the rear wheels.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Oct 24 2015
    Perth, WA
    You don't need to touch the subframe. Remove the brake line, and push down on the control arms, they come out with spring compressors. Installing is made much easier using Bosch rubber grease.
    My respray thread
    Senior Member Two Rings Harriz801's Avatar
    Jul 14 2014
    Michigan
    Not sure what brand of coilovers your using, but there should be a flat edge on one side of the rear springs. That flat edge should sit against your adjusting collar. Check and make sure you've got the spring orientated correctly. There shouldn't be any kind of gap between the two.
    The opposite end should sit against the rubber insulator. You may want to consider installing your rear adjusting collar on the top of the spring instead of the bottom for ease of adjustment. Heres a link for reference. Scroll toward the bottom in the section called "the better way"
    http://www.a4mods.com/index.php?page...coilovers.html
    Mar 27 2016
    Scandinavia
    figured it out boys
    there are 3 screws that i had to tighten on the height adjuster in order to hold it down(that way theres no gab under it)
    its standing straight on there now
    thanks though!
