Page 1 of 3 123 LastLast
Results 1 to 40 of 111
Thread: V8 swap
    Sep 25 2016
    96&98 discovery, Audi a6, TRX 450r, xc700sp. 86 Ford bronco
    Upper peninsula of Michigan
    V8 swap
    I have a 98 a4 with a blown motor. Just recently purchased an a6 with the 4.2. now the delima I'm in is that I was told that it was a 2000. If you look at the sticker by the door manufacturing date is 11/00. Now that title says that it's a 2001. I don't know if it has the immobiliser or not. If so what do i have to do to bypass so I can get the motor to work? If anyone can lend a helping thought would be great
    Dec 10 2013
    Borden, Ontario, Canada
    It most likely does have immo. Get it defeated and you're golden
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Sep 25 2016
    Ok what do I have to do to wiring up to my body harness to the motor. And what's the best way to defeat it also flash the ecu for a manual. Will I need to run with the a6 gauges?
    Sep 25 2016
    I can do wiring. Not my strong point. Just got my first Audi last December. Use to older muscle cars. " Alot easier lol". The mechanical side and fabrication are my strong point. Thanks for the help BTW.
    Active Member Four Rings S4orgy's Avatar
    Nov 11 2008
    05' B6 S4 B.R. 2000 B5 2.8 B.B.
    New Britain/Farmington, CT
    Have an 02 a6 4.2 fully loaded if anybody wants it tuns & drives. Perfect for swap
    05' B6 S4 Brilliant Red 6MT: JHM 93 Tune ● JHM Ported Manifold w/spacers ● JHM Lightweight Pulley ● JHM Lightweight Flywheel ● JHM STG3 Clutch ● A.W.E. Catless 2.5" Downpipes ● Custom 2.5" Corsa Non-Res Exhaust w/x-pipe ● KW V3 Coilovers ● Stern Adjustable Upper Control Arms ● JHM Short Throw Shifter
    00' B5 A4 2.8 5MT: Gone
    Oct 30 2009
    Miami, FL
    A user here named bhusted did the same swap into a 99.5 and documented everything, look for his thread on it. The most difficult part is figuring out what wire goes where, after that it's a piece of cake.
    2018 S5 Coupe - stock for now
    Sep 25 2016
    I'll look for his thread thanks. Yeah everything is a breeze for me except figuring out what wires go where lol. Can the ecu be flashed for a manual transmission. Is so where and how much lol
    Sep 25 2016
    Does anyone know if a s6 ecu will work with my harness? Found out that my a6 donner car was manufactured 11/00. But says it's a 2001 on title. However I was looking at the key and it doesn't seem to have a transponder. Does that mean no immobiliser?
    Sep 25 2016
    I've also noticed that on a couple threads that the flywheel don't match up to the crank sensor. What's that fix?
    Mar 25 2015
    Finland
    Pretty sure that there is an immobiliser. Only difference might be that the older is immo2 and newer immo3.
    You don't have to get that manual flash right away. Just add the pin for the clutch and it works fine. I've been driving almost 4000km with my V8 swapped B5 like that, and there is nothing that tells me it's an automatic ecu.
    And reading those other 40V V8 swap threads really helped me a lot.
    Sep 25 2016
    Oh ok well then I still got to get past the immobiliser in the ecu. Yeah I've been reading alot of the v8 threads. Been really helpful so far. Haven't started yet, waiting for the new clutch, radiator, and all the seals and stuff to come in. Just trying to get all my ducks in a row if you know what I mean.
    Dec 24 2010
    2001 A4 4.2 v8 swap, MR2 Turbo, CBR1000rr
    Columbus, Ohio
    you will need to convert your car to DBW, get a V6 30v flywheel if you plan to stay 5 speed, 6 speed you will need s4 flywheel. There will probably be more wiring needed to be done on body harness side since yours is preface lift, the ideal way
    is to swap same year to same year- ie 01 a4 with 01 v8, makes things a lot easier, you will need 1.8t power steering pump.
    Message me if you have any questions. Immob and manual coding will need to be done on ECU, i have been running Daz tune and its amazing, unfortunately with his passing it would be hard to get.
    Nov 03 2011
    All Over!
    The V6 30V flywheel also works with an 01E 6-speed, and is actually preferable to the insanely heavy and tall 2.7T flywheel, which requires the 2.7T / 01E 11.5mm spacer, between the engine and transmission.
    With limited room at the front of the V8 in a B5, you need every mm you can salvage.
    1986 Type 85 Audi 90 quattro
    Sep 25 2016
    I understand the same years would be ideal. However there isn't much to choose from up here. Details about what to do for the wiring would be nice. Plan on taking pedals out of the 01 just need to learn what or where the wires go. Where could I send my ecu to get what's needed done to it? Should I egr and Sai delete? As you can tell new to the forum so would send pics but can't figure out how to yet.
    Sep 25 2016
    And what's the reason for having to use a 1.8 power steering
    Sent from my XT1585 using Audizine mobile app
    Mar 25 2015
    Finland
    You can use the 4.2 pump. But you have to also use hoses from 4.2 (that is how I did it. It helps a lot if you have the whole donor car.
    Sep 25 2016
    I do have the whole donner car. Plan to start on it this weekend. Seals and stuff will start to come in next week. I know I have work ahead of me with the wiring. If someone could point me in the right direction. It's a pre facelift b5 and a 01 a6
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    Good luck with this project be sure to post lots of progress pictures.
    I will be watching to see if I can assist with any information!
    Thanks,
    Alex
    Dec 24 2010
    Columbus, Ohio
    Quote Originally Posted by Tddybrwn269 View Post
    my motor is 00, harness and ecu are 01 i bought from a yard. wiring info is hard to find, best to research all the builds on here as wiring is different for every year/combination. pedals shouldn't matter as long as its from facelift. your essentially adding a plug into plenum box where you dont have one. message me for ECU info, i may have someone who can get a a delete and tune
    definitely delete SAI, i made my own blockoff plates, or get them from 034.
    i ran 40v PS pump with 1.8t pressure line and 40v reservoir to pump line, i said it wrong in previous post. its plug and play this way.
    If your not the best with German wiring i would try to source a facelift car and there isnt nearly the wiring work needed. you will want to go facelift cluster which is a lot of wiring and then deal with re pinning the plenum plugs as well, just my $.02
    Sep 25 2016
    Lol can't post pics. And the wiring doesn't bother me. But the knowledge of where it goes is lacking. Or having the wiring schematics. That's where I lack. The work I can do the know how I can't. Lmao. Not afraid to admit it.
    Sep 25 2016
    Sep 25 2016
    Sep 25 2016
    Sep 25 2016
    Well parts all ordered. Plan on starting to tear down next week
    Sep 25 2016
    Sep 25 2016
    Engine is ready to get out
    Sep 25 2016
    Sep 25 2016
    Making progress. Hard to get to work on it when you work 12 hours a day. Start to pull the v8 tomorrow. That's easy. Can anyone help with what I have to do for the wiring now. It's a pre facelift b5 and a 2001 a6. Thank you
    Sep 25 2016
    Nov 07 2010
    South of Heaven
    You mentioned model years not matching but keep in mind that Audi model years go from August of one year to July of the next. So a car with a build date of 08/2000 or 07/2001 are both 2001 model year cars. That being said a car with a 11/2000 build date is a 2001 model year car.
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    - 1991 Jetta G60 Coupe Syncro
    Sep 25 2016
    Quote Originally Posted by Corrado_Guy View Post
    Yeah I figured that out thanks. Just need a little help on how to wire the engine harness to the body
    Sep 25 2016
    The v8 is pulled. Making more progress. Can anybody tune my ecu? I can't find anybody to do it so this will all be pointless. I would like the egr delete, Sai delete, rear o2 sensors turn off, and need the immobiliser defeated, and flash it for a manual transmission. It's a 2001 7.1.1 ecu.
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    reflect tuning on facebook should beable to. I think it was like $60 to delete the immo.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Sep 25 2016
    Quote Originally Posted by King_ View Post
    Thanks I look them up
    Sep 25 2016
    So just a quick question. I noticed in one of the builds that there is a spacer used between the flywheel and crank. But cant for the life of me find it again. Anyone know what spacer to use. There was one on the v6 on the clutch side of the flywheel. Do I just put that one on the opposite side?
    Sep 25 2016
    Well ecu is getting sent out. Started going through the engine. found this depressing sight. The 2.8 has knew tensioners. Anyone know if they are the same? Looks like it however looks and are the same is two different things
    Dec 10 2013
    V6 and V8 tensioners are interchangeable
    IG: 24_et
    Sold:
    RIP:
    Sep 25 2016
    Start working on the cross member today. Still trying to figure out how to do the wiring. Just can't figure out what goes where. Also does anyone know if I'll have to change the tack or how to change it to v8?
    Dec 10 2013
    VCDS to code the tach for a v8. Wiring is like 3 wires only apparently.
    To eliminate rev hang, you gotta wire in something else
    IG: 24_et
    Sold:
    RIP:
    Sep 25 2016
    Quote Originally Posted by Bordom View Post
    Thank you on the tach. And for the wiring yeah I get only three wires but I'm working with a 01 harness and 98 body. The plugs are different. The pins for the body are round and the pins for the engine harness are flat. don't know if I should just cut wires and change the whole end or what. And of course the color of the wires do not match.
