Results 1 to 13 of 13
    Jan 29 2016
    Worcester/MA U.S.A
    Exclamation 2001 Audi a6 2.8L Super Flush
    Ok so a little while ago i mixed coolant. I feel like i should be put to sham ... But now i need to do a super flush so to speak . It's been in there for a little while and im seeing some black stuff in the coolant tank. The A6 operates fine. But now i'm stating to get worried since i found out that's a big F&^% up on my part . I want to know how i can clean it good and how much G12 or G13 im going to need.
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    i would bite the bullet and go to the dealer and have them do a complete flush and refill with g13
    should take about 2 gallons mixed
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Jan 29 2016
    Worcester/MA U.S.A
    Trust me i thought of it but i dont trust them to do a god job. but 2 gallons mixed? so that like 1 gallon of G13 and 1 gallon of
    distilled water
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    http://www.blauparts.com/audi_water_...eak_noise.html
    Take your time and don't use a flush.
    Sent from my Nexus 5 using Tapatalk
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    If you are confident, do it yourself. If not go to dealer like toast said
    Jan 29 2016
    Worcester/MA U.S.A
    Quote Originally Posted by AllroadMass View Post
    Are you saying replace the water pump? i did. all that stuff was done November. But i know i can do a flush but i was just wondering if theirs some chemical booster that i can run though the cooling system. to clean it good. theirs a lot of good right ups for a flush out there.
    Oct 30 2015
    Massachusetts
    Quote Originally Posted by Kearney36952 View Post
    No no, just wanted to share the article and that you shouldn't use a flush. Just water as stated in the article unless you're going to run a good amount of tap water through the system.
    Jan 29 2016
    Worcester/MA U.S.A
    oo ok yeah thanks they have meticulous articles nad i like them but yeah im going to run a lot of watter through it to clean it out and maybe some prestone cleaner.
    Jan 29 2016
    Worcester/MA U.S.A
    ok i cleaned it out and drove around for a day with Preston cleaner and distilled water no thers only water coming out but.. i cant figure out how to do a mix of 70 antifreeze 30 water 70/30 mix. like how much of either? idk i just cant wrap my head around the math i guess.
    Sep 17 2014
    New York City
    I dont know the capacity of your 2.8 but on my 2.7t i flushed it many times with clean water and after thr final flush i dumped a gallon of G13 concentrate and topped it off with water. Having no issues and coolant tester says im good for 20 below
    Jan 29 2016
    Worcester/MA U.S.A
    tbh that's like the same as i did i did a gallon of g13 and and 2L of water and topped it off with g13. the test does not show anything it maxes out at -45 but i think mixed it more for like -85 below i think according to the back of the g13 jug.
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    Be mindful with your antifreeze concentrations. The higher the concentration of antifreeze the lower the heat carrying capacity.
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Sep 17 2014
    New York City
    I read you are not to go past 70/30 and thats for artic climates. I wouldnt trust that mix.
