Sorry for the re post.I posted this in chatter box and could not move it .
Ok guy i have been reading everything I can pull up on the forums trying to solve this . I have a 2008 a4 2.0t 147,000 miles (I bought it with 141,000) . Labor Day weekend I decided to do a cam follower I did not know the condition of it being I just bought the car . When I did the service I pulled fuse 28 and ran the car dry changed the follower and reassembled . The old follower had the black coating worn off and a some wear to it . I drove the car and everything seemed fine . The next morning I drove to work and the car if I remember right ran ok .( don't run it hard at 4am and still a little sleepy ) . Car sat all day till 5 pm and on my was home going over the Ortega highway in C.A. (Mountain roads) I went to give it some throttle and car had no go and would not go past 4,000 rpm.I drove that way for about 20mile with no cel . I got home and pulled codes p0299 and p0101 . Everything I read was the diverter valve , so I pulled and installed a go fast bits dv+. And changed the air filter and cleaned the maf . These had no effect on the car . then I changed the pcv valve and fuel filter. Still no change . I ordered my Ross tech cable and checked my maf readings 1.82-2.0 g/s at idle and 28-30 g/s at 4,000 rpm 2nd gear pull . I also watched the boost and had ~950 mbar across the board idle trough all gears and rpms . My fuel pressures seem ok but saw my low pressure fuel pump was at 63% duty cycle befor the filter change the up to 67% after . I ordere a new maf and will be here Monday but not convinced this is the fix . Can anyone please help me ?
