    Senior Member Two Rings lockeed's Avatar
    Feb 06 2010
    Quebec
    B7 How to remove the upper bolt for the bracket linking the turbo to the engine block
    To be honest, I wanted to remove the diverter valve and check for damages and which revision it is as just bough the car a week ago. Car was parked for 3 months due to a cam follower that failed. Long story short, I spent an hour trying to remove the upper hidden bolt on the damn thing I couldn't get it out.
    I've decided to pull my turbo out instead to clean it and then check the diverter once it's out of the car. Main reason behing this is; I got the P0234 code after the follower replacement. Car would go into limp mode as soon as you asked for 50% + power.
    I've done everything on the list for the turbo removal, except one which I can't... the upper bolt for the bracket linking the turbo to the engine block. It's hidden under the turbo and behind the heat shield, near impossible to reach. Any hints?
    This is the bolt I'm referring to once it's out, you can see the bracket still attached.
    Sun: E90 M3 6MT or E46 M3 6MT // Snow: B8.5 A4 S-line Quattro
    Established Member Two Rings AudiholicA4's Avatar
    Nov 09 2013
    Cincinnati, Ohio
    Could try an Allen wrench and then put something over it to try to break the bolt free
    Feb 06 2010
    Quebec
    Was able to reach it with a long hex bit, pulled as hard as I could on the 3/8 wrench and could loose it. I ended up removing the turbo without lousing it, I actually loosen the bracket at the other end, where the support bolt into the block. 2 larges bolt. It enabled me to pull the turbo assembly out easily.
    Nov 09 2013
    Cincinnati, Ohio
    So you were able to remove the turbo then? Is that your turbo^
    Feb 06 2010
    Quebec
    Yes I was, what a nightmare... First time I took one out of a TFSI B8... All the major components where out in an hour or so, but I've spent 5 hours on that last bolt and 1 or 2 on the upper diverter valve bolt that's hidden... Just stupid how much time someone can loose on a single bolt.
    - - - Updated - - -
    No, it wasn't my turbo, just a random pics from an how to.
