I'm getting a MAF error, and I already tried cleaning the G70 sensor with no success. I also used VAGCOM, and noticed that the mass airflow is at constant .67g/s regardless if I rev up the engine or not. I even tried driving around, and that number will just never change.
A few weeks ago, I did remove the head cylinder and there for removing the turbo and exhaust manifold.
So my question, is this a bad sensor or it's possible there's a vacuum leak?
I'm getting only two codes...
Code:
2 Faults Found: 000257 - Mass Air Flow Sensor (G70) P0101 - 004 - Implausible Signal - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 267114 km Time Indication: 0 Freeze Frame: RPM: 1894 /min Load: 57.2 % Speed: 104.0 km/h Temperature: 84.0�C Temperature: 36.0�C Absolute Pres.: 980.0 mbar Voltage: 13.716 V 005634 - Power Supply Terminal 30 P1602 - 002 - Voltage too Low - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: -40.0�C Temperature: -40.0�C Absolute Pres.: 0.0 mbar Voltage: 0.000 V Readiness: 0000 0000
