    Senior Member Two Rings Corrado's Avatar
    Apr 07 2010
    MidAtlantic
    2000 S4 - Stage 2 upgrades, 6-SPEED MANUAL, AWE, GIAC, CLEAN!
    CLEAN TITLE, CLEAN CAR, STAGE 2 UPGRADES, 6-SPEED MANUAL TRANSMISSION, ADULT OWNED
    Ebay Auction - click link
    http://www.ebay.com/itm/201684890040...84.m1586.l2649
    More pictures and information on Ebay listing
    For Sale is a 2000 Audi S4 2.7T quattro sedan.
    This car runs great and sounds great with its Stage 2 upgrades including an AWE Twin 2 exhaust system.
    Nice deep rumble:
    As its second owner for the past 9 years, I have babied and taken great care of this future classic.
    Enjoy!
    Performance Modifications
    AWE Twin2 Dual Exhaust System, 304 stainless steel
    VAST Performance High Flow Piggy Pipes
    K&N 57i Intake Induction Kit
    GIAC-X Software, including hand-held flashloader with stock and pump tunes
    ST Suspensions Coilovers
    034Motorsport Silicone Throttle Body Intake Boot
    034Motorsport Silicone F-hose
    034Motorsport Track Density Front Strut Mounts
    034Motorsport Street Density Transmission Mounts
    034Motorsport Street Density Motor Mounts
    034Motorsport Snub Mount
    FCP Control Arm Kit
    Akebono Euro Ceramic Brake Pads
    ECS Tuning Stainless Brake lines
    Technical Highlights
    6 speed manual transmission
    Anti-lock brake system
    quattro IV permanent all-wheel drive with Torsen center differential
    HP2 4-pad high performance front brakes
    Safety/Security Highlights
    Driver & front passenger airbag supplemental restraints
    Driver & front passenger seat mounted side airbag supplemental restraints
    Inflatable SIDEGUARD curtain airbags
    Xenon high intensity discharge headlights
    Anti-theft vehicle alarm system
    Headlight washer system
    Front fog lights/rear fog light
    Audi emergency kit
    Comfort/Convenience Highlights
    Silk Nappa leather
    Electric climate control with sun sensor
    60/40 split/folding rear seat
    Electronic cruise control
    Driver and passenger 10-way power seats
    Bose premium stereo
    OEM rubber floormats
    Tilt and sliding glass sunroof
    Other Highlights
    No CEL codes/check engine lights
    Some pixels out on dash cluster
    Driver's side rear window is not working
    Shifts nicely, no grinding on the 1-2 shift
    Headliner in good shape, not sagging
    18x8 AMG replica wheels, pristine condition with 225/40R-18 Kumho Ecsta LE Sport tires, tread is low
    Extra set of 4 OEM Avus 17" wheels and 205/50R-17 General Altimax Arctic Snow Tires, included in sale
    Ice-cold A/C
    Heat is weak, system may need to be flushed
    Carpeted Floormats included in sale
    Owner's Manuals included in sale
    Always serviced with Rotella T6 5W-40 or Mobil 1 0W-40 synthetic oil
    Always serviced with quality air/oil/cabin filters, MANN or similar
    New battery in September 2016
    New dashboard cupholder, works perfectly
    This vehicle is sold as-is in very nice condition with a few light scratches and wear. Mileage current at time of listing, may increase slightly. The high-resolution photos of the vehicle clearly show the clean condition inside and out.
    Included in this sale are all associated parts I have removed from this vehicle such as the OEM engine cover trim, OEM valve cover trim, and OEM air-snorkel.
    Shipping to be arranged and paid for by the buyer.
    Sep 22 2016
    Queens NY
    Please provide info on maintenance. Timing belt, heater core etc.
    Apr 07 2010
    MidAtlantic
    Quote Originally Posted by Doc_Rodrigo View Post
    Bumping this up.
    Had to relist due to neglient buyer.
    Timing belt, water pump, thermostat, serpentine belt, spark plugs (NGK), fuel filter, diverter valves, cam cover & seals, cam plugs, and tensioner gasket were all done at 87,000 miles. Service was performed by AWE Tuning in PA when they installed the Twin2 exhaust.
    Ebay link:
    Apr 07 2010
    MidAtlantic
    Sunday bump.
    Added some more info on service history.
    I have a thick stack of service receipts to be included in the sale. Highlights in addition to regular oil/filter changes include
    81,000 miles - power steering flush, power steering reservoir, brake system flushed
    86,000 miles - battery
    87,000 miles - central locking unit, timing belt, water pump, thermostat, serpentine belt, spark plugs, fuel filter, diverter valves, cam cover & seals, cam plugs, and tensioner gasket
    91,000 miles - auxiliary water pump
    92,000 miles - left front window regulator, left front window switch
    95,000 miles - right front window regulator
    99,000 miles - O2 sensor, coolant temp sensor
    105,000 miles - left and right front outer CV joint boots
    109,000 miles - left headlight Xenon ballast
    125,000 miles - ABS control unit, air bag module, rear wheel bearing, coolant reservoir & cap
    130,000 miles - fuel pump, fuel filter
    134,000 miles - O2 sensor
    139,000 miles - PCV (spider) crankcase breather hose, front & rear rotors, front & rear pads, valve cover gaskets, cam chain tensioner gasket
    149,500 miles - battery
