I'll be quick to the punch as I understand this topic has been beat to death. For the record !!! I have researched till my eyes bled out! So please just humor me.
2006 A4/B7 95k miles
All stock other than integrated stage one tune.
Rough idle in park/and neutral. Almost violent shaking. Fine otherwise. Good pull and torque at speeds.
This is everything that has been done previously to the problem starting and everything done after trying to fix the problem.
Whole cam warranty job complete.
Low pressure fuel pump
Fuel filter
Fuel regulator valve
High pressure fuel pump module
New om coils
Numerous types of spark plugs and gaps (trial and error) currently Bosch side fire platinum .
New n80 valve
New pvc/crankcase valve
Informally checked for vaccum leaks (can of carb cleaner sprayed at any possible vaccum line).
I currently am scanning a code of P0171 system bank 1 too lean..
However I have also been scanning numerous other codes. Here is the report....
Here are some screen snaps of the live action at idle...
So there you have it.... Anyone wanna take a stab at this one. All help is greatly appreciated. Thank you!!!
P.s. I understand about the torque converter issue and am still reading up on that possibly being the culprit. However seems like that would have been a ongoing issue from the start...
