After it rains, it sounds like I have a small lake sloshing around under the driver. It seems to be draining either in front of the left rear wheel or just behind the left front wheel and takes several days to drain. My footwell is not wet. I looked around and found it common to sedans with sunroofs, but we have a cabriolet. I removed the battery and blew out the two holes there with compressed air and snaked a wire through them; poured some water down there and it drains out by the engine bay.
I removed the driver's rear wheel and felt covering and found no drainage holes there/anything I checked was dry. I blew out the entire area at the bottom of the windshield with compressed air. There must be some drain holes in front of the driver area windshield, but I can't find them. Can anyone confirm this? Can't figure out why water would be collecting where it is. Any help appreciated. Some pics I took if it helps:
