Results 1 to 9 of 9
    Established Member Two Rings Rusty Axle's Avatar
    Jun 26 2013
    Syracuse, IN
    2013 S5 VAG-COM Parking Brake Reset Issue
    Got new pads / rotors on front then moved to back, with expectation that I'd be able to retract the parking brake without issue since I have a Ross-Tech VAG-COM cable and software. But, like any other piece of software in existence, the documentation apparently hasn't kept pace with the version releases.
    I have Vsn 16.8.1:53, and ran the firmware update that Ross-Tech suggests (actually, it seemed I wouldn't be able to use it without updating).
    Following the instructions to open parking brake the steps are
    SELECT
    53-Parking Brake
    Basic Settings 04 - enter Group 007
    When I choose Basic Settings 04, instead of a screen that allows me to enter the Group code and initiate action, I get a pull-down screen that lists the following:
    EEPROM RESET
    END LINING CHANGE MODE
    EOL RESET
    FORCE AUTO ADJUST
    MAXIMUM BRAKE TEMPERATURE RESET DEVELOPMENT
    RESET ACTIVATION COUNTER LEFT BRAKE
    RESET ACTIVATION COUNTER RIGHT BRAKE
    RESET HIGHEST BRAKE TEMPERATURE REACHED
    START LINING CHANGE MODE
    START OF OPERATIONS
    Based on the selections, 'start lining change mode' seemed like a reasonable choice. Choosing that presents a 'GO' button at the left and a blank box about 30 characters wide seemingly awaiting an entry. But there is no opportunity to enter text nor numeric information.
    I tried 'Start of operations' as well, thinking maybe I needed to tell the controller it was going to receive a command. Same results.
    Thanks in advance for any guidance re how to get the parking brake retracted.
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Did you try selecting "GO" in Start Lining Change?
    Jun 26 2013
    Syracuse, IN
    Nope - didn't think of that.
    The empty field to the right implied some sort of entry. But maybe that's why there is no ability to enter anything. Odd that the field is presented though vs. simply the 'Go' button. I'll give that a try in the morning.
    Feb 27 2014
    Dubai
    Do a you tube search, there's. good guide on there.
    Jun 26 2013
    Syracuse, IN
    The correct answer is to select 'Start lining change mode' and press the 'Go' button that appears on the subsequent page, but only after cycling the parking brake on and off a few times in advance. If the cycling isn't done, an error message will appear.
    Turns out the blank field to the right of the "Go' button is a message field, which gives status of operation while in process. So that explains why it wouldn't accept text or numeric input.
    The on line demo on the Ross-Tech site shows the process for prior generation cars and also current models, however it is two presentations with the current generation demo being the second one. If there was an explanation or any info pointing this out on the Ross-Tech site, I missed it, which caused me to dismiss the demo as not being current since I was watching the one for prior generation machines.
    Ross-Tech phone support was quick with the answer, although I was on hold for close to 5 minutes even though I was the first caller in the queue.
    Junior Member Two Rings
    Jul 15 2014
    Polska
    Hi. I have a problem with 2013s A5 parking brake basic settings. I clicked in vcds basic settings: force auto adjust and "GO". But basic setting is not ending so i clicked stop. Now i have fault code: 262656 no basic settings. What is the procedure of basic settings force auto adjust?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    This may help: Clicky click®
    Jul 15 2014
    Polska
    Thank's i try this
    Jul 15 2014
    Polska
    It works!! Thank you! But i have stil one problem. I repleced ABS Unit in 2013s A5. Coding and vin stored corcectly. But i have fault in ABS. 00493 G419 no or incorrect basic settings. How to do this?
