Results 1 to 14 of 14
    Active Member Four Rings
    Sep 14 2009
    s.e. mass
    Exclamation 00 BB S4 - PB5 STK 5862 Build Out... Done
    First Fire - https://scontent.cdninstagram.com/t5...14064136_n.mp4
    The "Tin Can" 2000 Brilliant Black S4
    PB5 STK Kit w/ Custom ceramic coated 2" wg & 3.5" dp hood dump
    PTE5862 .63A/R turbocharger
    Tial 44mm MVS wastegate / 50mm BOV
    PB5 Intake Manifold
    PB5 Ceramic Coated 2.8 Manifolds
    PB5 3 Port VTA catch can *STK fitment
    PB5 450/85 drop-in fuel pump kit
    Bosch Ev14 1000cc injectors
    2.0T FSI Coil Conversion
    PB5 EFK Kit
    PB5 3" FMIC & Bracket Kit
    PB5 Custom Charge Piping w/ PMAS HPX blow-thru maf
    TTV Billet Steel Flywheel
    Modified B7 RS4 PP & Hybrid Kevlar Clutch Disc
    Metal Slave & SS clutch Line
    B6 3.0 O1E Transmission
    Stasis Engine, Stern Trans, BFI snub, Apikol Diff mounts
    Wilwood superlite front BBK
    300mm B6/7 Rear upgrade
    & a little bit of custom parts here / there
    STOCK Block/Heads/Throttle Body & Major Chassis/Component Weight Reduction
    I'd like to form a build thread on the latter to post results/track times/you name it.
    Maybe a moderator or Anthony himself will allow me posting privileges in the builds section again, I have several to share with you all...
    Enjoy...
    IG: @PB5S4
    May 20 2012
    San Jose
    That open dump should sail through MA inspection no problem
    Veteran Member Three Rings -Billy's Avatar
    Feb 13 2013
    Altoona, PA
    What diameter is that charge piping? And why do you route it that way instead of from the throttle body to the driver side? Charge piping is one of the last things I have to do..
    Aug 25 2012
    Elmore alabama
    I just spent the last last 5 minutes wondering why it was a part out. Lol it looks sweet! I like the greenish and orange colors in the engine compartment. What horse power and why did you stay stock internals??
    Sep 14 2009
    s.e. mass
    Quote Originally Posted by oppositelock View Post
    Whats an inspection?
    Quote Originally Posted by -Billy View Post
    2.5" hotside, 3" coldside
    I routed it this way because it looks better IMO. You can route it however you choose
    Quote Originally Posted by S4tech2 View Post
    Thanks, there is quite a few different finishes of powder / ceramic going on here; to show off some of the different stuff I offer.
    Stock motor because I have a few of them that I dont mind blowing up for "r&d" purposes.
    The car is fairly lightweight and coupled with the drivetrain setup it should lay down some great times.
    Most of my customers do not have built engines, this is somewhat of a guinea pig to show them what it can do with my STK kit and proper supporting mods.
    IG: @PB5S4
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Quote Originally Posted by naudlee View Post
    Don't get me wrong here, I'm curious to see what this car will do.
    That said, wouldn't most people be more likely to drop in rods than a trans swap and gutting their car?
    That statement just seems odd when you consider it.
    Sep 14 2009
    s.e. mass
    I have an engine w/ rods and 2.8 heads ready to drop in, or numerous stock engines. I really just wanted to see it break 10's on a stock motor if I can drive it well enough. We'll see
    IG: @PB5S4
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    Looks good. I like to see a finish project the first post.
    Veteran Member Four Rings Cgoon009's Avatar
    Mar 02 2013
    I have a garage? Do tell...
    DC
    Will this car be at H2Oi? I know its a bit of a hike, but I would love to see this in person.
    Eurosport Tuning at it's Finest
    Sep 14 2009
    s.e. mass
    I wont be at H20 this year in this, it would have to be a trailer queen if I did.
    I'll get more current pics/info as I have the time to update.
    IG: @PB5S4
    Aug 24 2014
    Newport Beach, CA
    Great looking build Nick, that car should be a monster. Love all the custom work too, really clean install.
    2024 M3 Comp xDrive
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    Nice work
    Sent from my SM-G930T using Tapatalk
    Senior Member Three Rings astondan4's Avatar
    Feb 20 2015
    2001.5 S4 built RS6-R 6spd E85
    Norwalk CT
    Thats a sexy exhaust set up you have there. Should be nice and quiet.
    Aug 25 2012
    Elmore alabama
    That's a good way to look at it, I'm curious if it can break 10s myself. Would be pretty cool if it did.
