Results 1 to 6 of 6
    Active Member One Ring I3jorne's Avatar
    Aug 29 2016
    Stockholm
    Stock grille measurements
    As the title suggests I'm looking for the measurements of the stock grille on the C6 since I'm gonna try to fit the mesh into my A4 B7 S-line frame
    Top/bottom width and height would be great.
    -A4 B7 2.0T Quattro
    Jul 17 2011
    Sin City, USA
    Top corner to corner is 28", bottom corner to corner is 20" and overall height is 20". These measurements are to the outer edges of the frame. Frame on my grill (aftermarket RS6) is 3/4" inch on the sides and bottom and 1.5" on the top.
    '09 C6.5 A6
    Aug 29 2016
    Stockholm
    [IMG]Pictur[/IMG]
    Great thanks!
    -A4 B7 2.0T Quattro
    Senior Member Two Rings se.farrell's Avatar
    Jan 10 2014
    Los Angeles, CA
    Sin's got you covered. But TBH, I would highly advise purchasing one (provided you are not trying to do some crazy fab design).
    You can pick one up really cheap nowadays, the build quality will most likely look much better (just an assumption) and you always have the original to either sell or swap in when you sell the car.
    Just my 2 cents...
    Current:
    C7 A6 3.0T Prestige - Glacier White
    STAGE 1 | TSW
    C6 A6 S-line - GONE
    Aug 29 2016
    Stockholm
    Quote Originally Posted by se.farrell View Post
    Just my 2 cents...
    You do have a point... but I don't know if you're familiar with the mod, but it does involve cutting the mesh from the ''frame''
    -A4 B7 2.0T Quattro
    Jan 10 2014
    Los Angeles, CA
    Quote Originally Posted by I3jorne View Post
    Semi-familiar. I looked into doing what I assume you are talking about with my fog grilles, after I swapped in my RS grille. If you look there is some really good mesh out there - there is an ebay seller in Germany who has the exact size.
    If I had an A/S4 it would be easier because I could have just bought the RS4 DTM fog grilles to match the RS grille mesh. Oh well....
    Happy modding!
    Current:
    STAGE 1 | TSW
    C6 A6 S-line - GONE
