Results 1 to 6 of 6
    Jan 25 2015
    Phenix City, Al (was Mich.)
    4.2 FSI...need intake manifold actuator & linkage
    The linkage going from the intake manifold actuator to the lever is missing. Looking closely at the actuator....it looks like it broke off! The variable manifold moves freely with no issues. I don't necessarily need a new one, does anyone know a source for a used actuator and linkage arm? Thank You...
    Jan 24 2010
    Paramus,NJ USA
    I believe they are only available as a kti in the aftermarket and are made out of aluminum.Gruven parts makes them for the rs4 and some other cars.Not for a q7 but they might be your best bet,maybe they make a set that will work.
    Ziddy Autowerks
    Jan 25 2015
    No luck finding the actuator and link arm at Gruven. Luckily I did find one on-line, someone was selling an intake manifold, and I asked if they would sell the actuator separately - and they agreed. Whew...!!!! These items are not easy to find, and NOT cheap.
    Jan 25 2015
    Hello Gang....just an update. I eventually found a used actuator for $100, which in not too bad considering a new one is almost $400.
    Veteran Member Three Rings zerokiller698's Avatar
    Nov 11 2011
    NKY
    I missed this thread. The V8 S5 shares about 95% of engine components with the 4.2 Q7. So you don't have to just look for parts off of Q7's.
    Current: 07' Q7, B6 S4
    Past: B5 1.8t, B6 S4, MK2 VR6
    Instagram: Zerokiller698
    Jan 25 2015
    The actuator I got came off of a 2007 A8L. Thanks for the tip....I'll keep that in mind.
