Results 1 to 13 of 13
    Feb 09 2014
    Alameda, Cailfornia
    Which Bilstein works best with S-line/Sport Suspesion (Black B4s vs.Yellow B8s)?
    I own a 2007 2.0T/6MT Quattro S-line with the factory sport suspension and 18" Titanium Package wheel that is basically stock.
    My intention is to keep the suspension close to stock and possibly try out an RS4 rear ARB after I renew the shocks.
    I am debating between the black Bilstein twin-tube B4 OEs (which come in a length compatible with the "sport" suspension") or the yellow Bilstein montube-tube B8 sports.
    I had concerns the yellow B8 sports might have too much dampening in relationship to the factory sport suspension springs?
    Thanks Stoic B7
    Nov 21 2014
    Montreal
    I just got my B4 OE Sport shocks installed with sline springs and have the RS4 sway bar.
    https://www.ecstuning.com/b-bilstein...t/19-164472kt/
    My car didn't have sport suspension originally, I just wanted the stock sport suspension. Handling is pretty good now and still comfortable. RS4 sway bar does very well with stock sport suspension. I wouldn't want to go any lower or stiffer.
    Oct 24 2015
    Perth, WA
    The B8s are a better shock and should be fine with sport springs, however you could always change the springs too. I did that last weekend.
    My respray thread
    Mar 08 2011
    union, nj
    FYI the B8 sports are 3/4" shorter and are for lowering springs, Bilstein also have the B6 which are the HD valved liked the sports but same shock length as oem. I debating as well as to go with sport springs, coilers or just the B4 replacement. Good luck which your choice and keep us posted
    Feb 09 2014
    Alameda, Cailfornia
    Talked with Bilstein on Friday B6s are not compatible with shorter factory sport suspension. B8s are suppose to have same valving as B6s but shorter stroke which is compatible with shorter factory sport suspension springs.
    The cost increment for using B4 (sports) vs. B8s is not the concern, I just do not want a jarring ride from having to stiff of a shock.
    Thanks
    StoicB7
    Aug 29 2016
    B7 Avant, MK4 GTI, R52 Pathfinder
    I have a 3.2 avant with sport springs that I just put HD's on two weeks ago, they have been great. I also wanted to go with the HD's in case I decide to raise it to get a little more ground clearance.
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by stoicb7 View Post
    Thanks
    StoicB7
    Yep, that is what I used too.
    My respray thread
    Mar 08 2011
    union, nj
    I'm glad you did talk to bilstein, I might go that route then with the B8 and sline springs.
    Veteran Member Three Rings konarider94's Avatar
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    If you can, get someone to gut a groove in the front shock 3/4" below the one that comes on it then move the spring perch down. It will make your car sit level instead of the normal s line reverse rake. The B8 shocks are pretty nice.
    2018 A5 S-Line Manual
    Mar 08 2011
    union, nj
    Quote Originally Posted by konarider94 View Post
    Hows the ride quality? I don't care much about the reverse rake, but thanks for the tip, who knows maybe one day lol.
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    Ride quality is great. I don't think you'll notice it being any more harsh than the factory sport shocks. I was over 150k miles on the original shocks so it was quite the improvement in ride quality for me.
    Feb 15 2016
    Cambridge,Ontario
    Olay from this I understand if I have a b7 sports suspention option ( red) which I do. I can go straight to bilstein b8 shocks ?
    You guys aren't buying these from the stealer are you ?
    Is there a bilstein part number ?
    Nov 15 2011
    Montreal | I sell in USD
    Try Essex distribution. They're the Canadian Bilstein reseller. I think Germanparts.ca is also having a great sale on Bilstein for sport suspension
    *****I sell in USD*****
