Results 1 to 3 of 3
    Veteran Member Three Rings Dannaye's Avatar
    Mar 20 2014
    1968 Oldsmobile 442
    Orlando FL
    If I had my pistons replaced under the recall would a carbon cleaning be bene...
    I currently have 112K, I had the recall done at about 85K. The cars idle isn't bad since I've replaced the motor and tran mounts. But I do have a loss of power and read a carbon *could* help that.
    EDIT - This is me assuming they did it along with the piston job (which I have a high doubt for)
    Instagram @Dannaye
    Jan 24 2010
    Paramus,NJ USA
    Piston job is just that a piston job.Chances are Carbon buildup was not cleaned.If there was any present,normally I would assume they would try to upsell that cleaning while the engine was apart.Long story short the piston job is an extension for just a oil burning issue.It has nothing to do with carbon on the valves or in the intake tract.I believe warranty on the piston job still is 12 month or 12k miles whichever comes first.
    Ziddy Autowerks
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Do a CC anyway at this mileage. It won't hurt. Find a place that does walnut cleaning if possible. Loss of power could be a lot of things. Are you still on the original turbo?
