Results 1 to 16 of 16
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Loading the Suspension Before Tightening the Bolts Clarification
    I just recently completed the driver side as part of my prolonged suspension rebuild project.
    I understand the car needs to be loaded prior to tightening the bolts on the bushings.
    Prior to beginning work, I measured the ride height to be 16" inches (from center of axle bolt to fender liner border) // I believe ride height is also described as being measured from ground to fender liner border
    When I torqued the bolts yesterday, I recall maintaining the distance of 17" from axle bolt to fender liner. Car was on jack stands and bottle jack was used to raise the driver side.
    Is that one inch going to make a difference? Or am I better off loosening and re-tightening the bolts with the distance measured in the beginnining (16" inches to be exact)?--mind you that these bolts are apparently one-time use only--the ones attached to upper mounting bracket (upper control arms) and subframe (lower control arms))
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    May 16 2008
    South Texas
    You want to be as exact as possible, any preload on the bushing will wear it out prematurely.
    Jun 10 2013
    United States
    You won't get it any closer unless the wheels are on. The wheels load at a farther distance from the chassis which gives more leverage and more compression.
    Dec 27 2014
    2013 Audi Q5 3.0T
    My issue is that I have the vehicle on Jack Stands, not on shop ramps. The accessibility is pretty limited when using the jack stands.
    Have I already caused damage to the bushings? Will I need new hardware to go along with the re-tightening of the bolts now? I believe these are one-time use bolts. Or can I just loosen the bolts--and re-tighten at the appropriate height?
    Current:
    70,xxx Miles
    182,xxx Miles
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    loosen and re-tighten
    ive used the same bolts before, it holds in place just fine
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Dec 27 2014
    2013 Audi Q5 3.0T
    Thank you PaperToast, will do once I'm done with the passenger side
    Quote Originally Posted by PaperToast View Post
    Current:
    70,xxx Miles
    182,xxx Miles
    Apr 29 2009
    Quadzilla
    Longmont, CO
    Quote Originally Posted by arjun90 View Post
    kool, anything to help you sleep at night
    Rockin' the Rockies
    Sep 11 2009
    NE
    I normally just put a car jack under the wheel hub knuckle and lower the car onto it. Then I manipulate the jack under the hub to obtain ground-to-center-of-hub distance EXACTLY to what the other side of car is at right now, assuming it has wheel on and it is on the ground. IF the other side is in the air, then using jack stand or another car jack I put down too to the same height as if it had a wheel on and was on the ground. All of this to ensure that everything sits at normal ride height.
    You might ask why am I doing this to the other side before settling the side I am working on down? This is to eliminate any influence of sway bar as sway bar is nothing else than additional spring force provided by linked spring on the other side.
    Once this all is settled, you preliminarily tighten the bolts as much as you can to ensure they don't move and if you have access with torque wrench then finish the job, if not, mark the the bushings-to-bracket line across the ones you're working on and jack the car back up. Verify nothing moved, that's why the markings, and go all out on torque wrench.
    It is very simple but I little daunting at first.
    And no, you haven't destroyed bushings yet but driving around with improperly tightened-at-ride-height ones would eventually do that.
    Dec 27 2014
    2013 Audi Q5 3.0T
    Thanks julex, by the way, does the following diagram hold true for the Audi A6 C5 3.0L?
    Current:
    70,xxx Miles
    182,xxx Miles
    Sep 11 2009
    NE
    It should since it is using the same parts as other C5s and ride height is about the same.
    Dec 27 2014
    2013 Audi Q5 3.0T
    Sway Bar Bushings
    Current:
    70,xxx Miles
    182,xxx Miles
    Apr 29 2009
    Quadzilla
    Longmont, CO
    i never have, just the c-arms
    Rockin' the Rockies
    Jul 27 2011
    Collegeville, PA
    Don't sweat it. Remember that the allroads vary ride height by several inches (sometimes more when the air bags fail).
    Dec 27 2014
    2013 Audi Q5 3.0T
    Thanks, although I must say--torquing the upper control arms then adding that extra 90 degree turn was dreadful with the upper control arms already in the car, lol
    I did not torque them at exactly the 57mm (+2/-2) specification when outside the vehicle; I'd be surprised if anyone can be that precise . I jacked the suspension up through jack stands to load the suspension--both sides are at equal ride height now; should be around 57mm.
    I believe the sway bar bushings need to be torqued to 18 ft lbs
    The sway bar links are apparently supposed to be torqued when the suspension is loaded, I think I did somewhere close to that--its what happens in limited space and when there is lack of access to a hydraulic lift. The Bottle Jack worked perfectly though, the car "almost" lifted off the the jack stand.
    Current:
    70,xxx Miles
    182,xxx Miles
    Dec 27 2014
    2013 Audi Q5 3.0T
    Pretty satisfied with how it all went with the suspension refresh.
    Current:
    70,xxx Miles
    182,xxx Miles
    Sep 11 2009
    NE
    I just did coil over swap to ST Coilovers this weekend, plopped each corner on second jack stand, exactly 13.5" from ground to center hub to simulate height that it would have when on wheels and impact wrenched lower bolts with 80lb +-200% until I could not move the bolts/nuts with my hand wrench, good o'le gutentight. It is not going anywhere.
