Results 1 to 15 of 15
Thread: Stereo Help
    Sep 24 2016
    Hawaii
    Stereo Help
    Hi all,
    So i just got my 2013 S4 yesterday, and after I tore up the road I wanted to check out all the features. So, I connected my phone via Bluetooth, but noticed I couldn't stream music. Then I realized there is no Navigation either. Is this like the cheap-o stereo option that I got? Is there a way to upgrade to the Audi stereo that has the Bluetooth audio feature? Or maybe a part to interface with the stereo? Obviously I'm new, so please forgive my ignorance.
    Thanks xoxox
    Mar 21 2015
    Yup you got the el cheapo stereo. Can't help you with the Bluetooth, sorry
    Apr 05 2016
    Portland, OR
    Navigation is an option, you must not have it.
    For bluetooth make sure it is enabled on your phone.
    There should be two check boxes
    Call Audio
    Phone Audio
    By default only call audio was checked on my phone.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    I believe bluetooth audio was only included with the navigation package for the B8.5 cars? If that is the case, you would need to purchase an aftermarket solution. The ViseeO Tune2Air works very well. If you have an iPhone, you may need to disable the BT for phone calls while using it, though, or you may hear skips and pauses in the music. There are a few threads on this topic.
    https://www.amazon.com/ViseeO-Tune2A.../dp/B00R2HZ1XU
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I believe all B8.5 cars do have bluetooth regardless if that have Nav/B&O or not. I have the Tune2air in my 2011 with Nav and B&O
    Sep 24 2016
    Hawaii
    So, after doing some more research on the topic, it apperas that if the vehicle doesn't have the Nav option, then I can only connect BT for phone calls because I have the AMI Stereo. Upon further research, it seems that the ViseeO will not work because I have the AMI and not MMI, so I need the Audi BT adapter. Can anyone verify this?
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by mcswee View Post
    The Tune2Air connects via AMI connector (in the glovebox). I have a buddy that has a non-nav 2014 and he uses the T2A. He has the WMA1000 though. Not sure what the difference is between the two models. I think maybe one has the AMI plug and the other just plugs into the 30-pin iPod connector.
    https://www.amazon.com/ViseeO-WMA100...6/ref=pd_ybh_1
    Sep 24 2016
    Hawaii
    Quote Originally Posted by jsh139 View Post
    jsh139, you may be my savior. It seems like that part should work. I couldndt find the Audi adapter (4F0 051 510 J) anywhere. Thanks!
    Jun 06 2016
    Florida
    If you're planning on buying a WMA1000, I'm selling mine for $50 shipped. I decided to hard wire my phone instead, so it was only used for a couple of weeks and it's in like new condition.
    2018 Daytona Gray S6 | S Sport | Black Optic | Carbon Atlas |
    2011 Phantom Black S4 | S-Tronic | P+ | Nav | Sports Differential | Titanium Package | Silk Nappa | SOLD
    Sep 24 2016
    Hawaii
    Quote Originally Posted by Dirt View Post
    PMing you
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    No problem, hope it works!!
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by Dr GP View Post
    Bluetooth yes.. Bluetooth Audio .. no ..
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Senior Member Two Rings Quidproquo's Avatar
    Aug 06 2015
    2013 Audi S4, 2007 Nissan 350Z Enthusiast
    Morris County, NJ
    If your Audi came with the Concert Radio, you will need the WMA3000 if you don't currently have the glovebox adapter.
    https://www.amazon.com/gp/product/B00S320660
    This part is plug and play, just set up your phone's bluetooth to it and start playing your tunes by selecting the MEDIA button:
    You can change the song using the center dash screen, or the left steering wheel controls.
    2013 B8.5 S4 DSG (034 Motorsports intake tube | air box mod | aFe Pro Filter | CTS+183mm Iabed Pullies | EPL Dual Pulley 93 Pump Tune | SunTek 35% Tint | 19" S5 Rotor Wheels)
    Sep 24 2016
    Hawaii
    Quote Originally Posted by Quidproquo View Post
    Yes, thats the stereo I have. I do have a cord in the glove box for an ipod connection. So do I just need the WMA1000?
    Thanks for the help!
    Aug 06 2015
    Morris County, NJ
    Yup. That should work. I don't think there's much of a price difference, so I preferred the hard wired WMA3000.
