Onto the passenger side,
I was using an angle grinder to cut up the pinch bolt from the nut-side (a Dremel just wasn't fitting into this tight spot). A little frustration led to the formation of a a less than 1mm cut into the spindle (pictures attached) . It doesn't feel or appear that deep. Do you all think I need a new spindle? Or should I be good to proceed forward with drilling out the pinch bolt?
Thanks
