My loss is your gain!!
Sold my 2006 A4 a few months ago for financial reasons and just got this block back from the machine shop.
Bottom End:
-IE Tuscan I-beam Rod Set $600
-JE 82.5MM Bore 92.8MM Stroke 10.5:1 CR 2.0T FSI Pistons $600
-Calico Coated main and rod bearings $225
-1.8t oil pump conversion (removes all balance shafts for less rotational mass) $500
Head:
ARP head studs $200
034 Head gasket COMPRESSION DROPPING HEAD GASKET, 0.5 DROP, $175
Eurojet Aluminum valve cover powdercoated $600
Asking for less than what I have into the labor ($1400) and parts ($2900).
This is a bare block and does not include any accessories. You will need to finish assembly, if you want me to include any accessories then I will sell them extremely cheap, just let me know what you might need. It has a new rear main seal, and water pump, tensioner pulley etc, but WILL need to be timed. Timing belt has not been installed at the current time.
$3000 local pickup, $3500 shipped anywhere in continental 48. Thanks for looking - PM for more info.
