Results 1 to 9 of 9
    Apr 10 2016
    Chicago NW burbs
    How to change the "Trunk Trim Panel" (8T0-863-471-4PK)
    My trunk trim panel got scratched and I would like to replace it. I found the part number: 8T0-863-471-4PK
    The panel looks like this:
    http://parts.audiofalexandria.com/pr...05704_zoom.jpg
    The part seems simple enough. Do I simply remove the rubber and pull it out? Or are there two push pins at the bottom that need to be removed?
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    Plus remove the spare tire
    Apr 10 2016
    Chicago NW burbs
    Does anyone know the type or part number of the push pins involved? I tend to replace them when pulling them just because.
    Senior Member Three Rings drdrewusaf's Avatar
    May 31 2012
    San Antonio Texas
    There should be 4 metal clips holding the panel onto the body. The diagram at the link below shows only 2 clips, but I just did this on my 2013 about 2 weeks ago, and there were 4.
    http://www.audiusaparts.com/oe-audi/8t08634714pk
    These are the metal clips:
    Move the rubber out of the way, then carefully, but forcefully pull up on the panel in the general location of the clips. The two pins at the bottom are guides.
    Drew
    May 28 2012
    May 31 2012
    San Antonio Texas
    Quote Originally Posted by Luis_Heineken View Post
    Yes, precisely.
    Drew
    Apr 10 2016
    Chicago NW burbs
    Thank you!
    So, then no plastic pins.
    BTW. What is the luggage net (21)? Was that an add on option? Mine doesn't have it.
    May 31 2012
    San Antonio Texas
    Quote Originally Posted by Meadowdale View Post
    Thank you!
    No plastic pins, and the luggage net is an option.
    Drew
    Mar 24 2013
    Southeast
    I have a trunk net no longer being used if anybody is looking for one. I bought a weathertech trunk mat and don't use that anymore- perfect condition
