I am almost ready to pull the engine on my 2.7t 2000 A6 quattro. From reading the Bently and watching a few good videos, I have a few questions.
First, I see what looks like an EGT sensor on the passengers side near the turbo. I don't have the heat shields off yet. Is there one on the drivers side, I would assume that there is one on each side. If so, where is it located?
Second, One of the video's tells about the importance of removing the vehicle speed sensor prior to engine removal. I have a manual TIP transmission. W
where is the vehicle speed sensor located. I"m following the wires on the rear fire wall, drivers side and I can't see it.
Third, Where do you hook up the chain to pull the engine? I have a black metal Loop on the drivers side that looks like all of the other hoist locations I"ve used in the past....but I can not find another hook/loop for the chain to attach to on the passengers rear or drivers rear?
Thank you for the help!
