Results 1 to 17 of 17
    Mar 10 2016
    breaking up under boost
    hey everyone, my awm b5 has a stage 2 tune on it, 22psi peek. Made by kompressed. Just put new plugs in (bkr6e .028), coilpacks are all good, and last time it was checked on vag-com (a month ago when it was tuned), there was no codes besides having no map sensor in. Map is in now and it runs great no CEL or codes. However, under load, about 12psi+ it breaks up a lot. It runs great besides then. I know usually breaking up under boost is because of plugs gapped wrong, but i just put new ones in today. Thought putting new plugs in would help the prob but its the same as it was before. Any idea what it could be? RPM sensor? MAF?
    Thanks for any input!
    '01 Audi A4 1.8TQM - stage 2 daily
    '95 BMW M3 Coupe S52 swap - RIP
    '01 Audi S4 K04 Stage 3 - stolen
    Established Member Two Rings czum09's Avatar
    Nov 02 2010
    1999 Audi A4
    Cedar Rapids, Iowa
    I personally run the Bkr7e. And I actually gap mine slightly tighter.
    Veteran Member Three Rings PringlesInVic's Avatar
    Oct 31 2015
    '05 Touareg V8, '11 MkVI Jetta TDI
    Victoria, BC
    Have you done the ICM delete? Any oil on plugs or in holes?
    I was having a similar issue with Bkr7e's at .036 I think, then gapped them down to 0.028 and it smoothed out.
    Try gapping them down a bit and see if it helps.
    SOLD - '98.5 A4 1.8TQM - Aluminum Silver Metalic
    REVO Stage 1 - BW K04 - CTS Test Pipe - Milltek Exhaust - ST Coilovers - Hyperboost DV - ECS Snub - TFSI Coils/ICM Delete - eBay SS - Valeo SFW - DEPO Ecodes - 18" BBS Reps - OEM RS4 Grille - Alpine/Hertz Stereo - PODI Boost Gauge + POD
    Build Thread HERE
    Mar 10 2016
    Quote Originally Posted by czum09 View Post
    i didn't know about going colder plugs, cause I'm still ko3. And you gap tighter than .028??
    Quote Originally Posted by Pringle420 View Post
    no ICM's on an awm, built into the coils. They're the push in coils. And no oil. Ill test out different gaps and if that doesn't help then ill try a step colder and different gaps. They're cheap enough and easy enough to switch out for testing
    Nov 02 2010
    1999 Audi A4
    Cedar Rapids, Iowa
    Mine are gapped to .024. It is recommended to use the colder plugs on any tuned A4.
    Dec 05 2007
    6E stock, 7E tuned in relation to NGK plugs. Purchase Bosch F6DTC plugs. They last roughly 25k before needing replacement, 3 prong, and require no gapping, and just a better plug. Ran this plug on flashed ECU for stock turbo when I had that setup.
    Mar 10 2016
    I've seen a lot of people running the 6E with a .028 with the same setup as mine. Heard the 7E wasn't necessary, but ill have to try them. Might go bosch also. Plugs are cheap so i might try a few different sets with different gaps and see what it likes best. Thanks!
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    Quote Originally Posted by NickW3 View Post
    One step colder in theory is what elevated boost applications should run. It keeps the cylinder temperatures in check with the increased boost levels.
    For gap, there is no set gap you should run. You want to run the largest gap you can without experiencing misses. If you miss, close it down some which is probably why the one fella is running .024.
    I second the Bosch plugs though. They really are superior for preventing spark blow out with the tri electrode and last considerably longer than the NGKs.
    Sent from my LG-H815 using Tapatalk
    Mar 10 2016
    I've tried everyone's suggestions and I've tried every gap under the sun lol and am currently running 7E's. None of the plugs or gaps changed anything noticeable, still breaks up at the same boost in any gear. It's not even just a miss, it's more like a rolling 2-step. Think it could be a bad coil or the coil harness causing this? Like I said it's fine anywhere under ~12psi. Thanks in advance
    Nov 02 2010
    1999 Audi A4
    Cedar Rapids, Iowa
    It could be a coil. Or it could be a vac leak. I actually bought the F6DTC plugs, noticed a huge difference. I'm running them from here on out.
    Mar 10 2016
    I was thinking vac leak too, but I'm at ~19 inches at idle so it seems fine. Maybe I'll try those plugs too
    Oct 24 2011
    New Jersey
    So you mentioned there were no codes, does the check engine light flash when you are breaking up? If so it should record a DTC that you can read with VCDS and share.
    Do you have the ability to data log it? I would like to see separate logs (to keep logging rate up) of boost req, actual and n75 duty cycle vs rpm, knock voltages vs rpm, ignition angle vs rpm and injector duty cycle vs rpm.
    Mar 10 2016
    Quote Originally Posted by Believer View Post
    i wish i could data log, but i don't have vagcom. I've been meaning to get it for a while but other things have come up. And it doesn't flash, it did one time, the first time i tested the new tune, but besides for that it doesn't.
    I just noticed it does idle a little rough, when you listen closely. About every 5 seconds there's a miss, just like a stutter. And also since i got the tune, it's hard to drive normal. At 2050rpm it slams higher in rpm. No matter how much throttle i give it, it feels like it slams into boost even though it won't be in boost, and then over 2050 rpm its responsive and normal. Under that rpm the engine is a dog and feels like a constant bogging state. Thought it was just the tune causing it to do this, vtec type thing. Maybe a bad n75?
    ill try to get the cheap vcds cable and free software soon so i can figure these things out myself lol
    Dec 05 2007
    You can download the Torque app and pick up an obd2 bluetooth reader. Pay the money for the full version of the app, and it would be easier to help. You can datalog as well as checking for dtcs (and other features). Will cost like $15 all said and done.
    I run Maestro but use this most times. Got a cel tonight (has been a while) and will just use this app to see what it is and then clear it.
    Mar 10 2016
    Thanks a lot! I'll look into that. It doesn't have all the features as vcds, but it's basically just a code reader?
    And what was the exact app you bought?
    Dec 05 2007
    Not all the features, but is also more than a fault code scanner. You can datalog certain things, get estimated hp using weight of car and speed via gps, and other stuff. Name of app is Torque. Then you pay for the full version.
    Mar 10 2016
    thanks! ill be sure to get the app. Probably vagcom too because I've wanted (needed) it for a while lol
