Results 1 to 7 of 7
    Veteran Member Three Rings scott99c2's Avatar
    Oct 11 2014
    Nashville, TN
    Oft discussed, sharp turn vibrations
    Gang,
    I've had lots of Audis; S5, S4, A8, A6, and I've never noticed the slow turning vibration like I have in my S7. Is it just a chassis thing with the C7? I'm running Pzeros, is it less with a decent tire? (Yes, I hate Pirelli)
    Just looking for any insights. If there's a link someone can point to me, my searches were fruitless because I couldn't figure out how to describe the phenomenon either.
    Scott
    2013 S7 | Prestige | Estoril Blue | Lunar Silver | SRM RS7 +4mm Turbos | SRM Short Intakes with RS7 Airbox | DS1 Stage 4 ECU | APR TCU | AMS Catted DPs | AMS Cooling Package | OCarbon Large Weave Carbon Package | Alu Kruez | Eurocode Sways | HRE FF01 20 X 10.5"
    2021 SQ7 | Prestige | Black Orca Metallic | Black Optic | Luxury Package | Laser Lights | Tow Pkg |
    Mar 30 2015
    Denver
    Plenty of info out there. Bottom line, it's pretty normal, harder tires can often make it more noticeable. Honestly, I'm surprised if you've not observed it in any of your previous Audis. It's caused by the Quattro system - and happens to other AWD cars as well, but for some reason seems to affect Audi's more.
    Could spend days reading on the topic https://www.google.com/search?q=quat...ning+vibration
    PS. Solid color combo you decided on for your S7 :)
    2013 S6 - Estoril Blue - Lunar Silver
    Oct 11 2014
    Nashville, TN
    Quote Originally Posted by cohall View Post
    Thanks, I appreciate the response. It's been a while since I've had an Audi, actually. I went from an S5 to a BMW x-drive, then daily drove a 911 Turbo for a while before this... the BMW and the Porsche don't do this, and I am getting old, so perhaps it was always that way!
    I wanted either white or Estoril, and the used car factory only makes so many cars to choose from! I wanted really low miles, so that made it even harder (bought this one with 15k).
    Scott
    Veteran Member Four Rings Xtek's Avatar
    Jun 09 2013
    Its generally referred to as "Quattro binding." Like stated above it has to do with the AWD system and the diffs. Its normal.
    - Chad
    2014 S6 Estoril Blue - APR Stage 1, AWE Exhaust
    I have USB HEX+CAN VAG-COM cable, if you need mods let me know.
    Oct 11 2014
    Nashville, TN
    Understood, just seems more pronounced on this chassis, which made me ask. Maybe I'll buy new wheels and tires anyway ;)
    Senior Member Two Rings FourRings115's Avatar
    Sep 28 2016
    Hoboken
    Quote Originally Posted by scott in cincy View Post
    Where are you located? If it was cool (less than45 or so) when this happened and you are still running summer tires, it can contribute. Especially when you have wide front tires.
    Google "acorn effect". Having driven a 911, I thought you may know about it. At this time of the year, the acorn threads always start up on the Rennlist Porsche forums.
    Oct 11 2014
    Nashville, TN
    Quote Originally Posted by FourRings115 View Post
    The 996 turbo is a more mechanical and in the front, and I never noticed it. The 997 turbo is much more electronic (my current one) and I've been driving it daily while my trim is out and not at all like my S7.
    I'm in Nashville, so it's still warm here... too warm actually!
