Hi,
I'll go ahead an apologize for the long message, but for the love of God please someone help, I am completely lost as to where to go next... Here it goes......
In short, I am having some very strange issues with boost under heavy load, and also normal driving conditions. For example, if I am at a red light and I give my car all it has in terms of pressing the accelerator down, I will not go past 15 PSI boost. Another scenario would be if I am on the interstate going about 60 MPH and if I gear down to 3rd or 4th gear and give my car full load, the boost will increase past 15 and intermediately go up to 17-19 MAX, but it kicks back to 15 and holds.
I went to my local shop that installed it and I asked them what there experience was with their 2007 Audi A4 that they had in which they installed the same kit on the car and they are able to achieve 25-27 PSI under heavy load upon acceleration, and the boost holds. They also said that when they are cruising on the interstate going 60+ they are able to achieve 20-25 PSI while not going below 20 PSI.
I decided to have my car smoke tested and noticed a leak coming around the compressor cover on the intake side of the turbo. It was leaking 10 inches of air pressure. The smoke machine was set at 10 inches of pressure and it was bleeding smoke out of the compressor cover. We applied RTV to it and resealed it.. The leak was now gone, and we decided to test drive the car and I noticed immediate increase of torque and the boost PSI quickly reached 25-27 PSI under heavy load on acceleration and would hold. After we continued to drive the car for about 3 or so minutes coming to a complete stop and then accelerating again under same conditions, the boost pressure then would only achieve a MAX of 15 PSI under heavy load. We tried the interstate and giving it heavy load at 60+ MPH and it would get up to max 17 PSI, but would decrease like it was previously.
I checked for leaks AGAIN, and it’s not leaking anywhere, we’ve tried many times to locate something out of order, but not able to find anything.
I find this to be very strange considering that A) My car was able to achieve the boost that my friends car is able to produce for a VERY short amount of time before then going back into the same conditions as it was before.
I own an official VAGCOM cable and would be willing to do some tests if you think that is my next way to try and troubleshoot.
Please provide some incite as what to do next, I am under the impression that my car should be boosting much higher than it is currently, and obviously my car was able to achieve this for a short period of time, but now is back to the old conditions. It sounds like there is a software issue, or something is just off. I double checked the Diverter valve, and it has been upgraded twice to two different styles, no change, and no oil located in the diverter valve, or in the turbo itself.
Would love to find out whats going out, sorry for the long email, but just wanted to be as thorough as possible.
Thanks in advance
