Results 1 to 10 of 10
    Jan 12 2016
    Los Angeles, California
    ECU Tunes and MPG
    I've been eyeing an at home ECU tune for a while, but haven't made the decision to pull the trigger. The biggest downside to this car, for me, is the gas mileage. On many of the tuning sites' pages for their ecu tunes, they mention increased fuel efficiency. Has anybody noticed actual efficiency gains?? It would be awesome to imporve the gas mileage while driving sanely, while being able to get that added power when wanted.
    2016 Monsoon Grey S3 P+ w/ BO, Resonator Delete, AWE Resonated Catted DP, Unibrace UBQ, 034 Rear Sway Bar, 034 Dogbone Insert, 034 Rear Subframe Inserts, 034 P34 Intake, CTS Turbo Inlet, ED Springs, Eurodyne ECU and TCU
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    Quote Originally Posted by KevinM. View Post
    Depends on how heavy you are on the throttle. I usually get about 21-22 MPG in the city and about 28-30 MPG on the highway and I tend to have a lead foot. My city mileage would be a bit higher if my commute to work was longer than 6 miles 1 way. The car isn't getting to full operating temp until I am almost at work. I am on APR stage 2 with APR DSG tune.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Jan 12 2016
    Quote Originally Posted by Baggio View Post
    WOW! That is considerably better than my mileage. My 30 mile round-trip to school and back every day is a good mix of city and highway driving, and I am consistantly getting a combined 18mpg.
    Would love to hear is anybody else is experiencing such gains with an ECU tune
    Aug 28 2013
    I think the DSG tune keeps the engine in the powerband and makes it more efficient. I sometimes get 19-20 on 1 way to work, but like I said my trip is short.
    Veteran Member Four Rings HurrayFive's Avatar
    Jul 21 2013
    Remote
    I have similar mileage numbers to Baggio and the same tunes.
    I did before/after comparisons on the same roads at the same speeds with both my A5 and S3 and when you're just cruising there was at least a 1-2MPG difference (improvement) at the same speeds on the same roads; they (and by they I mean most tuning companies) optimize fueling for performance and for cruising, so you'll generally see an increase in economy even with a heavy foot.
    The S3 is a weekend only car now so I usually get on it at least once when I take it out, I do not take the car on the freeway if I can help it (rocks like a mofo out here), and my mileage average is usually 22.
    '25 M8 Comp GC Frozen Tanzanite on Ivory/Night Blue - 11.0 @ 126 bone stock
    Jan 12 2016
    Great to hear, currently debating between Unitronic and Eurodyne, leaning towards Eurodyne.
    Baggio, are you able to compare your pre-flash mpg with your post-flash? Its good to know what your current mpg is, but I believe it shows a better picture if you know what your net gain was.
    Appreciate your guys' help a lot!
    Aug 28 2013
    It was about 1-2 mpg less.
    Stage 3 Forum Advertiser Four Rings ModdedEuros's Avatar
    Aug 23 2014
    Philadelphia, PA
    We run Unitronic Stage 2 ECU/DSG on our S3 which is daily driven. As long as you drive normally its more efficient. But generally most people regardless of tunes tend to get the "heavy foot" syndrome afterwards lol
    Modded Euros
    Your Source for Audi & VW Performance Parts
    www.ModdedEuros.com
    Junior Member Two Rings
    Aug 16 2016
    philly subs
    i have noticed if i drive it like a 97 year old at night in the rain i get about 23 but in sport and winding it out a bit im lucky to get 18 and i can see the gas gauge going down.
    Oct 30 2012
    Arizona
    I generally drive in Dynamic Manual mode use its more fun. I get about 325-350 miles between fill ups.
