Results 1 to 29 of 29
    Mar 19 2016
    Colorado
    Moving to California
    Hey guys, I've done some searching and I cant seem to find anything. Unless I'm dumb, which I'm sure someone will point out I am. But anywho, I'm moving from Colorado to California here in a couple weeks. I've got a 2010 A4 with the Stg 1 APR tune. What do I need to know about emissions and such for the state to pass, and what can be done to the car to keep it (semi) legal to drive when I start putting more money into the car.
    Veteran Member Four Rings wxsgt's Avatar
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    they do sniffer checks and full computer checks. if you don't have a tune deleting rear o2 you'll be ok, but no test pipes and a hfc is very iffy. if they see it you'll fail
    Sent from my SM-G920P using Tapatalk
    2010 Ibis White Audi A4 P+ l Upgrades: RS4 grill, Akebono Brakes, Debadged, Solo Werks S1 Coilovers, Targa Trophy Stickers(guaranteed 10+ HP) l
    2009 Ibis White Audi S5 Coupe | Upgrades: RS Grille |
    Mar 19 2016
    Colorado
    So if I rock a HFC, just keep the stock cat and go through the pain to switch them for testing? Does the computer check see the tune and fail?
    Junior Member Two Rings
    Mar 25 2009
    Grapevine, TX
    There computers only check for fault codes, not software modifications. I had a B7 A4 with stage one for years and no issues passing smog.
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Quote Originally Posted by exolutionist View Post
    Might as well keep the stock cat on running the stg1 file....
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Aug 18 2016
    San Jose, CA
    Pretty sure they got rid of the sniffer test here in CA, I just had a smog done a couple months ago.
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    Quote Originally Posted by SukhShanti View Post
    according to their website they did not get rid of it. and as for a tune, some tunes simply stop a readiness check from happening so there is no cel some make the sensor disappear so it can't be checked but readiness is still checked. the latter tune should be ok the first is not as you must have readiness set to pass
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    No more sniff test in CA.
    They hook up to the ODB system to check for emissions system readiness and functionality, along with fault codes.
    The technician follows that up with a visual inspection for aftermarket equipment and CARB certification.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Keep it stage 1 and you should be fine. W wouldn't do a test pipe or HFC unless you are willing to switch them out prior to your test. Or just go buy a B9 and forget about smog for the next 5 years
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by hyperunion View Post
    From experiences I have heard, stage 1 with a HFC is the same power as Stage 2 with HFC. Stage 2 files just clear the O2. A few guys have been told this by APR shops, and GIAC could not find more power to be had with additional tuning after adding an HFC.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Sep 03 2012
    Lehigh Valley, PA
    Quote Originally Posted by blbroo View Post
    Definite gains running a hfc and st2.. especially with e85...
    But yes... No worries of cel's thanks to secondary deletes...
    Nov 23 2014
    '05 infiniti G35 coupe, '12 B8 A4 avant quattro
    Socal
    You can always look around for shop that can be bribed. I've done that when I need to smog my G coupe with custom exhaust. You will pay almost double what the regular price would be. They are out there.
    Sent from my ZTE A2017U using Tapatalk
    Mar 19 2016
    Colorado
    Quote Originally Posted by ichigoismyhomie View Post
    I mean, I'd like to be semi legit lol.
    With the HFC though I'm trying to get Stage2, and soon I'm going big turbo so I'm trying to see what the hell I'm going to have to do. Because in Colorado, they don't care as long as you're not loud.
    Veteran Member Four Rings awdconnor's Avatar
    Jun 07 2016
    Portland, Oregon
    where in california?
    I'm stage 2 with a HFC. Luckly, cops think you are a 50+ year old man or a rich 18 year old girl and don't hassle you.
    (Knocks on wood)
    [COLOR="#808080"][FONT=System][SIZE=2]2018 Audi S4 P+ | 034 Stage 2 E85 | Airlift 3P | BBS RSii
    Mar 19 2016
    Colorado
    San Diego
    Sent from my SM-N920T using Tapatalk
    Jun 07 2016
    Portland, Oregon
    San Diego
    not to far from me. you should be fine man. their more looking for subaru/mustangs out here.
    Mar 19 2016
    Colorado
    Quote Originally Posted by Tiggy View Post
    Which company stage 2 are you and do you have to finangle stuff for smog? Or do you just go as is?
    Jun 07 2016
    Portland, Oregon
    Revo.
    and the guy i go to in orange county, doesn't check in the engine bay. he just puts a mirror under neath and checks to see of theres a bulge where the cat should be. he said he's cool with HFC... but you never know.
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    Amazing how many responders here who don't live in CA (and likely have never been here) seem to know everything about our smog requirements
    1. AFAIK, there is no longer a "sniffer test" here (have had my B6 and B8 tested w/i last 2 years, no sniffer test).
    2. There are differing requirements re smog certification - urban areas, LA/San Diego Coastal corridor, entire San Francisco Bay Area, Sacramento area, and some Central Valley cities (Modesto, Fresno) have far stricter requirements than rural areas.
    3. CA law requires that you register your car brought here from another state w/i 30 days, although most folks wait 6 months or longer - then you'll need a smog cert.
    4. Re the poster recommending bribing a test shop, yeah Let's Make America Great Again, as long as I can do whatever I want
    Cheers
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. FCA Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
    Mar 19 2016
    Colorado
    Revo.
    So I might have to drive to orange County once a year or so lol
    Senior Member Two Rings shayan_a4's Avatar
    Jul 12 2014
    2014 VW GTI and 2014 mercedes SL550 2014 b8.5 audi a4, c7 A6
    woodland hills
    lol pretty much in cali, just dont get caught with anything and you should be fine hahahah
    Established Member Two Rings punkalex1's Avatar
    Oct 26 2015
    Orange County CA
    here in orange county cops dont bother much unless your all riced out. as for smog mine isnt due till next year so i cant chime in on smog, i have a 034 HFC that ill switch out to stock when smog time arrives. im not tuned and the CEL doesnt bother me much lol i knew a few shops that passed me from $240-$350 on my older cars but they since been shut down
    Veteran Member Four Rings Poodini's Avatar
    Oct 26 2015
    2016 Subaru Outback 2.5 Limited
    Fremont, NorCal
    I'm in The Bay Area and it really just comes down to word of mouth and finding a mom n pop outfit, checking on Yelp reviews, etc. no 2 shops are exactly the same when it comes to testing so best to snoop around.
    Established Member Two Rings Bayerle's Avatar
    Jan 16 2016
    alpine
    I'm moving from San Diego to Colorado !
    Join SDAC good group of knowledgable Audi owners and might have some good insite on shops to go for this
    Mar 19 2016
    Colorado
    Quote Originally Posted by Bayerle View Post
    Yeah I follow a couple of those dudes on instagram. Was going to get with them when I get out there. What part of colorado?
    Jan 16 2016
    alpine
    Join the Facebook group
    Up in vail / Avon area for the winter season ... Snowboarding is life
    Jan 16 2016
    alpine
    Also , pure motor sports is pretty much everyone's go to down here especially since you're already APR
    Give them a call
    Feb 24 2013
    CA
    Id have to go with you but dm me....
    Veteran Member Three Rings VNA4's Avatar
    Jun 20 2015
    San Jose
    I got one thing to say being from the Bay and owning an Audi.... Pay to play. =)
    For smog switch to stock, remove the HFC and ull be good
    S4 B8.5 2014
    KW H.A.S. / EuroCode ÜSS Adjustable Sway Bar / AWE Touring Diamond Black / 034 Stage 2+ / DP 187mm / APR Stage II Carbon Back Pipe
    20 x 10 et35 StanceWheels SF01 [PowderCoated Diamond Black]
    SOLD
    AUDI A4 B8 Premium Plus Sport:
    CTS k04/ APR k04 File / AWE Quad exhaust / FMIC: TR8
    VIP VRC 13 : 19X9.5 / Tires: 255/35/19 / Solo werks Coilovers / OE S4 Front Brake Upgrade Kit
