A friend and I had done a AFP swap into my AEG 99.5 GTI chassis. The drive by cable was converted to the drive by wire pedal and wired-in according to V hub schematics.
I have 2 issues that I wanted to see if any of you guys have had any experience with and/or maybe can provide some insight on:
1. Cruise Control - We had thought it was a faulty clutch switch but I replaced it and that didn't solve the problem. He told me to start there based on a non-changing vagcom reading (in what we believe to be the cruise control bank) he got when engaging and disengaging the clutch. Are there 2 cc switches?
If the brake lights going on/off when the brake pedal is pressed is the only indication necessary to determine that the brake switch works, that checks out too.
Which other switches/sensors would anyone suggest taking a look at?
2. Long cranking / inconsistent acceleration / random 300-400rpm revs after clutch pedal is pushed in. (I'm presuming these are all related so I listed them together.)
More often than not, I need to hold the key to crank the car for 5-6 secs and pump the throttle to get it to stay turned over.
When I say inconsistent acceleration, I'm referring to the experience that sometimes the car pushes me back in my seat when I'm accelerating and sometimes it reminds me of the 2.S we just took out...
I got new OEM crank and cam position sensors for cheap so I'mma change those in the coming days. In anyone's experience, if that doesn't remedy these issues, what else is a common cause to them? There are no vacuum leaks in the hoses either. MAF and O2s all new and seem to be reading normal. Throttle body clean, gas mileage sucks.
No CEL.
Relevant Mods:
-DRC268S (+ valve springs, retainers, seals)
-No cat, O2 sensor spacer
-3" custom exhaust (prepping for future turbo setup after sorting these issues out)
-UM Stage 1 N/A tune
-Autotech CAI
-eBay specials race header
Thanks in advance.
