Results 1 to 7 of 7
    Mar 31 2013
    Washington D.C
    Question Transmission acting up after car was in repair shop for other repairs.
    First of all I am new here so I apologize if this is the wrong forum to post this question in.
    I have an old 1999 Audi A4 quattro 1.8L.
    It was having different issues, but nothing related to transmission slipping up until After I had taken it to the shop. Then, the same day that I go to pick up the car, its having transmission issues such as when changing gears from 1 to 2, the car would basically rev up but the gear would not change, and then it would literally jolt into the new gear. Again, this did not happen before I took the car into the shop and if this was the case, I would have requested service on it first thing instead of the service that I requested below:
    These are the repairs I request and they were done(some actually created another problem):
    Headlamp assembly (used)
    Outer tie rods
    Rack and Pinion
    Window regulator rivets (my front passenger window motor was not working)
    Window regulator
    Control arm bolt kit
    Control arm_Frt/Rt/Uppr/Rear
    Wheel bearing kit
    Shop Supplies
    The car was in the shop for a little over a week. Got it back this past Tuesday. As soon as I drove the car off, the transmission starts slipping. The car REVS up as if going faster on the speedometer but it doesn't kick into the 2nd gear without a big jolt. The car NEVER did that prior to me taking it to that shop and I NEVER requested any work on the transmission. The car goes fine after gear 1 and 2 but its jolting violently when turning into those gears. IF there were any of these problems, I would have requested those repairs as first priority and would not have spent a dime on a headlamp assembly or the window regulator (they were problems I could do without, the headlamp was working fine, its two plastics snaps to hold it in place were broken, nothing of actual damage on the headlamp assembly).
    When I got back the mechanic said to give it some time to warm up a little and then go. I did that, and the car was only fine when I had to manually let my foot off the pedal when the car is about to shift into gear 1 and then 2. The car shifts fine to gear 3 and above.
    The thing that's driving me nuts is that the jolting and the revving never happened prior to me taking the car to the shop. And of course those would have been the first problems I would have taken care of had they were happening.
    Just today I also discovered that the window that they repaired works perfectly fine, but the door doesn't open from the inside. The lock goes up when you turn the handle, but the door doesn't open at all from the inside. This got me thinking that they don't know what the hell they are doing. They fixed one problem but created another. I am taking the car back tomorrow.
    On another note, the car's transmission is probably done by now, its jolting every now and then and warming up the car isn't going to do anything I'm assuming. I am no expert on this so I have no idea how to handle this situation. This shop has about 6 5-star reviews on Yelp and I haven't found a single negative or less than 5 star review.
    What is the best course of action? Also, is the car done? I got it used about 3 years ago at around 68k. Right now it has about 85k miles on it. The manual says nothing about transmission fluid, changing it, checking it (you can't, its a sealed transmission), so I am not sure what to do.
    SO sorry for the long post, but its really the first time I've had a car problem like this right after coming out of the shop.
    Please help.
    Established Member Two Rings cclarkb5's Avatar
    Feb 02 2015
    1991 Audi 90 20v
    Bellingham, Washington
    The transmission isn't sealed, you can check it and change fluid, it's just not as easy as a car with a dipstick. But if its slipping like yours is it's hard to say if fluid would help anything. Can always swap manual, but that's big $$ if you take it to a shop
    They last long if you treat them any better than totally shitty. | 1999.5 2.8QA Volcano Black Mica | 1991 90 20vQM Pearl White |
    Mar 31 2013
    Washington D.C
    Okay Thank you for that cclarkb5. Now I have a different problem that I didn't have before. First off I gotta take the car back and get the door fixed and then see why its doing that. The thing is it never did this before I took it to the shop, then I drop the car off to that shop and then a week later they tell me its ready, and the same day it starts slipping. What gives? I haven't driven the car like a maniac either.
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    It could be a coincidence or they drove your car maybe in tiptronic if your 99 has that and mashed on it. Maybe they just mashed on it in D? Hopefully they didnt do something to get you back in for repairs
    Mar 31 2013
    Washington D.C
    It could be a coincidence or they drove your car maybe in tiptronic if your 99 has that and mashed on it. Maybe they just mashed on it in D? Hopefully they didn't do something to get you back in for repairs
    This is exactly what I am thinking about. It CLEARLY wasn't jolting or slipping prior to bringing the car into that shop and after a week of agreeing to fix the car, they do the repairs that I asked for (And screwed that up as well) and then are completely ignoring the problem of the transmission when I mention to them that it wasn't jolting or slipping prior to bringing the car to the shop.
    Do I have any legal recourse in this matter?
    What should I do in this case?
    Thanks for your help.
    Feb 27 2011
    Winnipeg
    first thing I would do is scan the transmission for codes and check the fluid level. As for your door I bet they didn't clip the cable on the door panel and thats why it doesn't open from inside.
    Mar 31 2013
    Washington D.C
    Yes I will have another shop look at that or somehow figure out how to get these guys to do it, because this issue was strongly likely caused by incompetence of these guys. It simply doesn't make sense for a car to into a shop without any transmission slipping or the car jolting, and then come out doing that after a week of repairs.
    This is after they fix the door first.
