Results 1 to 6 of 6
Thread: B7 S4 seats
    Junior Member Two Rings
    Nov 29 2009
    01 T4 TDI, 78 and 81 Scirocco 16V
    B7 S4 seats
    just picked up an Avant, and do not like the leather seats. No bolster support at all :(. Looking for black. Let me know what you have
    Nov 24 2014
    DMV
    Any idea if B6 S4 seats are the same? If not I can source a set of recaro's.
    02 B6 A4 3.0 6MT Sport Package | Kenwood DDX9702S Double Din | Tint | B7 S4 Front Calipers & 345mm Brembo Rotors + Pads | Blauparts "U-Slot" Slotted Rear Rotors + Pads | ECS SS Brake Lines | APR Snub Mount | ECS Short Shifter | BFI Shift Knob | 034 Front Swaybar Endlinks | Lemforder RS4 Outer Tie Rods | SPC Adjustable Front Control Arms | Meyle HD Lower Control Arms
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    B6 seats will fit into B7, however will cause a code until you swap in airbag into them
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    Senior Member Three Rings Jey4's Avatar
    Apr 02 2013
    West Haverstraw/NY
    Quote Originally Posted by supple View Post
    Correct me if I'm wrong but the bladder has to be swapped into the passenger seat
    Sent from my Nexus 6 using Tapatalk
    -Jey
    Jan 27 2016
    Woburn, MA
    Quote Originally Posted by Jey4 View Post
    Yes meant bladder
    Nov 29 2009
    Quote Originally Posted by f0reignfeatures View Post
    Recarro's are ideal. What do you mean you can source?
