Originally Posted by
rainydaze
The Audi OEM sport package springs provide a 0.8-0.9" drop. In fact, if you convince me to get a bigger drop with Eibachs, coils, etc I might sell ya mine :)
Project Quattro
^ what he said. Audi sport suspension (which shows up in the classifieds sporadically) is the most mild drop, roughly 3/4 inch. It's enough to kill the horrible wheel gap, but it doesn't look low. That's what I have on my B8.5:
My previous B8 had the Pro Kit, which was noticeably lower and frankly too low for my extremely low tolerance for inconvenience in my daily driving:
If you get aftermarket springs, get a kit which matched with shocks like the B12 Pro Kit. If not, your stock shocks will fail in 10-20k miles and you'll be paying labor to fix it again.
Sent from the Pedal Responce boardroom
Project Quattro
You're correct, I think 1.2 is as mild an aftermarket drop as you can get. My car came with the sports suspension and I'm not planning on changing it; it looks good enough and it can clear speed bumps and parking garages no problem.
Edit: Even that 1.2 drop you will scrape sometimes and need to be careful driving around.
interesting that you've mentioned. Because when I bought this Non-S-line... the underside of the lip was immaculate without any scrapes. (I guess either due to the high suspension or the previous owner was careful). I checked out a few other S-lines at the time also and all of them had scrapes under the lip area.
So I kinda figured that even with 0.9 or 0.8" drop, you'd scrape... Hence why, Im not keen on going the 1.2" drop.
With the existing clearance, its actually about x3 fingers between the wheel arch and the tyre. (I know, Americans spell 'Tire' lol)... I used a tape measure and if it is to drop 1.2", then its actually less than x2 fingers in between. which is what the photos attached by the other uses above indicate also. It looks like the 0.8 - 0.9 S-Line clearance is the perfect all-rounder.
I guess the only remedy for that is to go Coil-overs, so then you have full control of how much you want to lower the car.
But springs is definitely a lot more affordable compared to full coilovers...
