Results 1 to 4 of 4
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    White LED Gauge Needle cluster PCB
    I have a modified a5 gauge cluster PCB for sale. the red needle LEDs for Speed, Tach, Temp, and Fuel have been replaced with white. the mileage indicated in the DIS is ~41,000ish. I believe that member @DavidB has the ability to augment mileage to match your vehicle. I also believe that this is an a4 retrofit, as you see it here being tested in my 2010 a4 !!!
    you can make you existing red needles white by carefully using lacquer thinner to remove the red paint, and then carefully re-applying white paint. many ppl don't understand that the paint is on the underside of the needle, making the rest of the clear needle a fiber optic 'light pipe'
    asking $80 shipped and prefer PP Friends & Family to avoid fees.
    Nov 05 2009
    '09 B8 A4 2.0t quattro '15 Q5 3.0T
    Chicago, IL
    I'm confused... why did you take everything except the PCB lol?
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    I performed the '@Avantagg a5 cluster retrofit mod' to my a4, which uses the housing bits from the a5, but retains my a4 PCB, so this is an extra PCB!
    Mar 23 2013
    southwest Va
    Good luck reaching david
