I wish I could say that it was my idea to just pull one side of the bumper away to do the torque mount install, but someone else mentioned that they were able to do it this way in one of the many random threads I read while researching the install.
Here are some tips:
1) Loosen the 3 bumper adjusters 1.5 turns. No need to loosen the 4th one on the far side of the driver's side headlight.
2) Remove the 3 Torx screws between the headlights
3) Remove the undertray
4) Remove the screws for the passenger side fender liner; I think there are 3 or 4. Whatever it takes to be able to peel it away to gain access with your ratchet extensions.
5) Remove the little screw that goes down through the metal part of the fender and into the plastic of the bumper. Right when you pull the fender liner back you'll see it about 5" in on the right. This screw is not talked about on the forums and doesn't show up in the DIYs, so I of course didn't remove it even though every shred of common sense in my body told me otherwise. As I pulled the bumper away from the quarter panel that screw cut a nice little trail through the tab it was screwed into. Luckily it attaches to a metal clamp type thing so when I reinstalled the bumper (after loosening the screw so the plastic tab would fit back in via the trail I had made; arrggghh!!!) it tightened down nicely. No one will ever see the damage and it's still functional so no biggie.
It's right where letter "B" points to in this picture:
6) Remove the 2 screws deep in the bumper and follow the instructions for removing the headlight. Once I pulled the bumper out from the side and then forward a tiny bit away from the car there was plenty of room to access the screws for the headlight and to unplug it. Hello Torque mount you pesky bugger!
I never experienced the car when the OEM mounts were new, so I can't give you any advice as to whether or not you should replace them with an aftermarket brand. My gut tells me you should leave them in and only swap them out if you are noticing excessive movement of the engine or you want to tighten the drive train further after you've replaced all the other mounts.
By the way; I installed the 034 Motorsport Rear Diff Carrier Bushing Inserts last night and the short cruise I took afterwards makes me thing I have finally removed the last bit of slop in my driveline. I'll need to drive it on some backroads though before I'm convinced though. Thanks again for suggesting replacing/tending to them : )
