Results 1 to 39 of 39
    Established Member Two Rings B5man17's Avatar
    Jun 24 2013
    MN
    JHM program switching
    So has anyone heard if JHM will be updating their ECU tune to be able to switch programs using the cruise control stock like they do on the B7 A4.
    Catless DPs, Magnaflow CB, 034 rear sway and end links, tint 20%, enkei ts9 pss (summer), BBS SR with R2 snows(winter), JHM R1 clutch and flywheel, JHM shot shifter, JHM shift knob, JHM tune, ohlins coilovers, stub trans and rear diff mounts.
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    I can. swap between stock and tune.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Active Member Two Rings chris4521's Avatar
    Dec 14 2015
    Toronto, ON
    How do you do this ?
    08 S4, 2.5" Catless downpipes, 2.5" Fast Intentions non-res, JHM Tune
    13 S4, ECS LT Intake
    Veteran Member Three Rings VroomTT's Avatar
    Nov 21 2013
    SE FL
    Quote Originally Posted by Silver Streakin View Post
    I'd like to know how your doing this too
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Its only capable for B7s
    Nov 21 2013
    SE FL
    Quote Originally Posted by Jake@JHM View Post
    I have a B7, please tell us more
    Veteran Member Four Rings pwest15's Avatar
    Sep 15 2013
    2017 S3
    Denver, CO College Station, TX
    Quote Originally Posted by VroomTT View Post
    Senior Member Two Rings richB7S4's Avatar
    Jul 16 2013
    MD
    Is the feature only available to those who flashed their ECUs after June 2016?
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    So is this option pre-programmed in? I thought the JHM tune overwrites the stock programming?
    Dec 14 2015
    Toronto, ON
    So this works with b7s4 ? Anyone tried it ? Looks like an a4 in the video
    Jul 05 2016
    Ontario, Canada
    I'm gonna give it a try when I get some time. It might be nice in the winter to keep my feet under me
    Nov 21 2013
    SE FL
    Was anyone able to verify this on a B7 S4? I keep forgetting to try it when leaving home
    Also, the above video (thanks for posting that btw) mentioned program 1 vs 2, but not which is which... So is 1 the tune and 2 stock, or vice-versa? How would we know on our car?
    I def wish someone had provided me with some details on this when I get the tune... (not a big deal, but it would've been nice to be properly informed or gotten something in writing I could keep in the glovebox)
    Established Member Two Rings scorpioS4's Avatar
    Mar 31 2011
    New Jersey/Delaware,Dover AFB
    Quote Originally Posted by richB7S4 View Post
    2nd this!
    also this!
    is there any particular reason why I would want to switch programs?? neat feature just now sure how it can be useful. I always want the tune on!
    2k5.5 Moro blue S4 6spd: k&n drop in/FI x-pipe cat back non res/Piggie DP's/JHM 93 octane Tune w-LA/Intake man. spacers/lightweight crankpully/JHM shifter Trio/JHM stage4 lwfw&clutch/Elbow Heater Bypass Kit/Led strip inlays & taillights (fly's V4's)/6000K D1S and 3000K HID Fogs /Cupra R lip/R.
    Mar 05 2004
    NoVA
    I've had the JHM tune (downloaded flash) for almost 2 years in my B7.
    Slot 1 is the tune and it defaults to it. Slot 2 is stock.
    You should be able to feel the difference between tune and stock. You just try the launch control... turnoff ESP and floor it... should stay at 5k RPMs.
    SOLD 1995 90
    Jul 16 2013
    MD
    Quote Originally Posted by scorpioS4 View Post
    2nd this!
    also this!
    One reason that i can think of is if you have 93 tune and 91 is the only premium available.
    Jul 16 2013
    MD
    Thanks for the info👍
    Aug 31 2011
    Lathrop
    Don't waste your time program switching via the video unless you already have the second program.
    Chances are you don't. Its a $100 option on top of the tune.
    Nov 21 2013
    SE FL
    So how would we have known that option was available? I just double checked the JHM site and don't see any mention of it. I can't be the only one who would've liked the option.
    Also, I specifically asked about program switching at purchase and was told it wasn't an option, now it was just an extra $100 all along?
    Don't get me wrong, I'm happy with the tune but something seems a miss here...
    Aug 31 2011
    Lathrop
    Its not something we actively offer for the S4 because the B6 does not have this capability.
    Nov 21 2013
    SE FL
    Def get that, but you are saying that it IS an option for B7's right? I specifically asked about it for B7, and it seems others were able to get the option.
    I went with the 91 tune even though my area has only 93 just in case it was't available to find 93 as a precaution. Had I know switching was an option, I likely would've done 93 and stock to get the right tune and have a way to safely run the car on lower oct when needed...
    Is there any option for current B7 customers to get that incremental functionality?
    Aug 31 2011
    Lathrop
    Yes it is available for 2006-2009 B7s only. Unfortunately 05.5 does not have this available.
    You could go 91 and 93 if you want as well.
    Veteran Member Four Rings Axel-'s Avatar
    Jan 29 2011
    2006 JHM Stg 1 SC'd S4 Avant 6MT
    Toronto, CA
    Ok, I have to ask, can stage 1 supercharger guys also get the dual tune option? (93 and 91).
    Sprint Blue B7 S4 Avant 6MT - 421whp/350wtq - Review of all my mods
    JHM Stage 1 SC - JHM IM - JHM 5R clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - JHM shifter - Trexturk DP - Magnaflow CB - Hotchkis RSB - JHM IS - 034 Adj. FUCA - STE Gauges
    Mar 05 2004
    NoVA
    I wish this would've been information provided when I purchased your tune.
    I called the shop that did the flash, and they want a half hour of labor to swap the programs.
    I know you don't want to give away the secret sauce; however, a list of options per model year and a list of what the tune does on your site (and provided to the tuners to offer to the customers) would be greatly appreciated.
    SOLD 1995 90
    Aug 31 2011
    Lathrop
    You could borrow a flashing cable and flash it yourself as well.
    Dec 14 2015
    Toronto, ON
    Agreed. Had no idea when I got my tune only a few months ago.
    Will now have to pay labour and take the time to get the car in the midweek to the shop so I can have 91/93 options.
    Aug 31 2011
    Lathrop
    Like I said guys, this is NOT something we actively offered because the B6 does not have this feature.
    Veteran Member Three Rings Tugboatguy's Avatar
    Apr 08 2008
    07 S4 , 04 A4 1.8T Avant , 05 S4 VF SC
    New Westminster BC
    So what would the cost be if you went 91 and 93?
    Aug 31 2011
    Lathrop
    An additional program is $100
    Nov 21 2013
    SE FL
    While we're at it, what is the limit # of additional programs? For example, could we get 93, 91, & stock? (so 3 switchable programs in my example)
    *Specifically for 2006-2009 B7 S4's*
    Aug 31 2011
    Lathrop
    Only 1 additional program, 2 total.
    Jan 29 2011
    Toronto, CA
    No offense Jake but just because B6 doesn't have this feature doesn't mean you can't advertise it for B7s. There are plenty of differences between B6 and B7 models.
    And you still didn't answer my question :)
    Aug 31 2011
    Lathrop
    Quote Originally Posted by Axel- View Post
    The 05.5 B7 cant use it either.
    Sorry, I missed it! I would have to look into that for the Supercharger. Off hand I don't think so.
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Now, that i would go for considering gas options on East Coast are kinda iffy sometimes (with our busted pipeline)...
    Jake, if I do buy the 91 as second option(flash myself because i have my own cable) to go with my 93... when you switch between "programs" as shown in video ^^ How do you know or can verify which tune I would be currently running ?
    TIA
    Tarl
    PAST
    2004 Audi (B6) S4 4.2L
    2006 Audi (B7) S4 4.2L 25th Anniversary Special Edition #167
    Current
    2015 Audi (B8.5) A4 2.0T P+ Sline ECS-Luft-Technik Intake System/Air Scoop v2/Silicone Intake Tract Set with turbo muffler delete, GFB DV+ VTA Performance Blow-Off Valve, JHM FMIC/ECU and TCU (Automatic 8 Tip Quattro) Stage 2 tunes. Cosmetic RS4 Honeycomb Mesh Front Grille and Fog Light Vent Grilles
    Aug 31 2011
    Lathrop
    Quote Originally Posted by TarlCabot View Post
    TIA
    Tarl
    One blink at a time is program 1 and 2 blinks at a time is program 2.
    You set program 1 and 2 when flashing. Basically the first program you bring over is going to be program 1 etc..
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    so on my current tune of 93 (VERSION: 0030 TYPE: Audi S4 NA MY2006 4.2L 6spd Manual 8E2910560 S0030-V1 LA DATE: Saturday, March 09, 2013 2:04 PM )
    it should be JHM 93 program one
    then OEM stock program two ?
    PAST
    Current
    Jul 16 2013
    MD
    Hmmm
    Veteran Member Four Rings evildsmr's Avatar
    Sep 13 2012
    04 Imola V8, '21 Army Green Taco
    Denver
    How is this not available for the b6 platform because I have APR tune and I have the option of switching between stock, 91, 93, & 100 octane files.
    Apr 26 2016
    Kia Sportage V6 - Wifes car
    Metuchen New Jersey
    Quote Originally Posted by evildsmr View Post
    and how do you switch between them?
    Sent from the S that used to tap
    My S used to have a tap, a valve slap... now it makes no noise at all! RIP
    Sep 13 2012
    Denver
    Quote Originally Posted by chain_slappins4 View Post
    Key in on position, cruise control stalk in on position, then hold set button for cruise control and wait for check engine light to flash. Number of flashes indicates program file. Release set button with desired file and then the epc light will come on. After turn key off then turn on. Done!
