Page 3 of 9 FirstFirst 12345 ... LastLast
Results 81 to 120 of 321
  1. #81
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    Quote Originally Posted by wangshuo1989 View Post
    Update, I got another issue after getting this recall. My engine oil temp will fluctuate (like goes to 170 and immediately goes back to 168, then goes to 170 again, and it happens all the way to 200), that's something I've never seen before. Car drives normal though.
    Quote Originally Posted by FWP! View Post
    I'm really confused as to how this update would affect oil temps. Maybe they have leaned out the a/f mixture some, causing higher EGT's and a warmer engine overall?
    Quote Originally Posted by XxSullyxX123 View Post
    Agreed ,,it's supposed to do with diagnostic thresholds for the cats. Maybe the temp stays the same but is being calculated differently.
    Hello,
    I also experienced the same quick flucutations in oïl temp. It just conforts me that it is not a physical oïl temp, but Something in the way the ECM calculate the oïl temp has changed.
    Best
    Mathieu
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
  2. #82
    Established Member Two Rings adrianm8's Avatar
    Jan 13 2013
    Edmonton
    I had the dealer replace my thermostat earlier this year and the day I took it back the shifting was all messed up on my DSG, basically car will hold gear and not shift up at WOT, and downshifts are sluggish. They told me they didn't do any software updates, but I have a sneaky suspicion they might have done this messing up my APR stage 2 ecu and tcu flashes. Now I'm waiting to try to reflash the apr software but my local shop doesn't want to do it because they can't get an answer from apr on whether they'll get charged for flashing me again. Such a headache...
  3. #83
    Jun 14 2015
    FRANCE
    Quote Originally Posted by audiBMWfan View Post
    This worries me. Sounds like the programming change is substantial and may affect performance. If it were just a change of a threshold to a more permissive value, why would DMV care? The fact that some people see higher oil temperatures after the ECU update, if true, confirms that the programming change affects engine operation significantly.
    Hello ,
    Yes, a change in engine operation should be very substential to alter oïl temp. (i think oïl temp is more rpm related, as water temp is load/combustion related).
    Especially, i noticed a ~ 5-6 °C rise in oïl temp at very low load on highway (90 mph).
    Also, i am now tuned again with a custom Stage 2 (one with one of the best reputation here in europe), and this oïl temp rise/fluctuations are still present. Seems that it is more the temp calculation that has changed.
    Or this ECM update could also alter engine parameters (A/F ratio ?) even when the engine is remapped ? may be only on partial loads ? That would be more in par with emissions requirements.
    What do you think, guys ?
    BR
    Mat
  4. #84
    Aug 12 2015
    Minneapolis MN
    I have a track event next week so think Im going to hold off on getting this done. Even though I actually had the engine light issue a month back sounds like there is no physical benefit to the consumer or the car. Just a way to alleviate the dealerships time
    2017 Audi RS7 Glacier White w/ Black Optics
    2014 Porsche Panamera Turbo Executive Amethyst
  5. #85
    Apr 27 2010
    West Chester PA
    My buddy (OP) just had this done and we were taking about it. Here is my theory:
    -They were frying cats due to the engine running rich with high EGTs and unburnt fuel getting into the cats.
    -the OEM Richer fuel maps were to resist knock in a wide range of temperatures and climates
    -Easy way of ensuring no knock on a FI engine is to run richer than needed Edit: That is the "safe" way to tune
    -The fix was to lean out the A/F ratios with new fuel mapping, lowering EGTs and fuel getting into the cats
    -This increases your cylinder and then coolant temps which people are seeing
    -In theory it would lower power output, but maybe they also adjusted timing and valve lift/duration
    Basically they remapped the ECM to run much leaner to avoid having to replace and expensive cat under warranty. They can also probably claim better MPG due to the leaning of the fuel maps.
    Just a theory...
    2015 S3 Daytona 1 Package | Unitronic Stage 1+ ECU | Unitronic Stage 1 TCU | H&R Sport Springs | CTS Intake/ Turbo Inlet | APR Turbo Muffler Delete | OEM Resonator Delete/ Flap Mod | Welded Magnaflow Tips | 19x8.5 ET 45 Forgeline ZX3R with 245/35/19 Conti DW | 20% Tint
  6. #86
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    Quote Originally Posted by RupertPupkin View Post
    Just a theory...
    Sounds like u know what ur talking about :)
    so the recall notice kinda lies about what they're actually doing. Not just playing with a sensor. Does this mean less burble to an already low burble exhaust? Or does our burbles have nothing to do with fuel hitting cats un burnt?
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
  7. #87
    Mar 04 2015
    Somers, NY, USA
    Also, I just bought a chipwerke. I wonder if it will affect how that works
  8. #88
    Apr 27 2010
    West Chester PA
    If i am correct, which I'm not sure then you would get less burble in the exhaust with a leaner map. There would not be as much "overrun" and not as much unburnt fuel in the exhaust which gives those sexy pops and burbles.
  9. #89
    Jun 14 2015
    FRANCE
    Just a theory...
    Hi there !
    Very interresting things
    Just one question: i thaught that leaning A/F ratio lead to high EGT's . You stated the contrary . Could you elaborate ?
    Another thing: would this hypothetical ECM change would be, or not, overwrited by a ECU tune ?
    I would be cool that some Tuners chime in ! ;o)
    BR
    Mat
  10. #90
    Apr 27 2010
    West Chester PA
    you might be right, I know its effect on the cylinder temps which is what prompted my theory when OP told me people said they had higher engine temps.
    Maybe the cat issue was completely fuel related and EGTs don't matter. I need to confirm that.
    I do know unburnt fuel hurts cats.
    Quote Originally Posted by Mat@1975 View Post
    Hi there !
    BR
    Mat
  11. #91
    Jun 14 2015
    FRANCE
    I think i see: (too rich) A/F ratio lead to low(er) EGT, but resulting unburnt fuel will potentially burn in the cats, leading to damage them. right ?
    I really would like the reality of this ECM recall and the impact on Stock and Tuned ECU Maps a,d parameters..
    please chime in if someone kwow ! ;o)
    BR
    Mat
  12. #92
    Jun 28 2016
    US
    Quote Originally Posted by adrianm8 View Post
    I hope you get your problem fixed, but you may have to wait 2 weeks. ;)
  13. #93
    Jul 12 2012
    '24 Wrangler 392, '24 Golf R 6MT, '13 MB GL450
    New England
    So, if I refuse the update and my cat goes, am I on the hook?
    Incoming '25 RS6 AE. Gone but not forgotten: '03 S6 avant, '14 S4 6MT, '21 RS6
  14. #94
    Aug 12 2015
    Minneapolis MN
    Quote Originally Posted by Daily Driver View Post
    Do you have a tune? If not I would say no your not on the hook...and if you do have a tune its not 100% that they would TD1 you for it unless they were looking for it. I thought it did mention something about a deadline...cant recall
  15. #95
    Oct 13 2009
    MN
    I find it interesting the recall letter specifically calls out about having a chip or tune.
  16. #96
    Mar 21 2015
    Quote Originally Posted by CrownSeven View Post
    It's technically not a recall and a few of the letters i've seen about S4's say that.
  17. #97
    Sep 05 2012
    My letter says 'recall' right on the envelope.
    I have GIAC stage 2 so I'm trying to figure out how this works. My warranty is up so I don't care about TD1.
    -If I did go in for the recall, does the Audi dealer have to do extra work ($) to remove the tune first, like the letter implies? Like, Audi can't just overwrite GIAC's tune? (Of course I could go to my GIAC dealer to go back to stock first.)
    -Does putting the GIAC tune back on wipe out the changes in the recall? Does GIAC have to make a new version of their file that includes these manufacturer changes? Sean from APR's post seemed to hint that APR is able to do a "merge" like this on the fly (?)
  18. #98
    Mar 04 2015
    Somers, NY, USA
    I received my letter today (day before I go in for 25k service). It says recall on the envelope and letter. Although on myAudi.com it doesn't show under recall area, but below it with a different heading.
  19. #99
    Mar 21 2015
    Quote Originally Posted by moose_head View Post
    If you look it up it says "service campaign" not "recall" even thought it says that on the letter.
    EDIT
    Wonder what the technical difference is though...
  20. #100
    Mar 04 2015
    Somers, NY, USA
    Right that's what they called it online. "Service campaign" sounds like a proper term for recall hahah
  21. #101
    Mar 21 2015
    I believe a recall is federally mandated, not sure.
  22. #102
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I find it VERY interesting they mention that. Maybe they think this issue is tune related?
    Sent from my SM-G925V using Audizine mobile app
  23. #103
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    ECM Software Recall 2016-09-21
    Anyone from mass do this yet? And would it affect getting a inspection sticker if we choose to ignore it?
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
  24. #104
    Aug 25 2013
    florida
    this is another example of how AOA doesn't actually do any non-accelerated life cycle testing on their post production campaigns.
    accelerated cycle testing don't mean shit in the real world and instead of just throwing codes at things and calling it day, they need to spend a few months driving in the fucking cars before releasing this garbage. same with the last steering update campaign before the airbag software campaign.
    2014 sfeux p+ 6mt bo nav w/o sd
  25. #105
    Mar 14 2015
    2015 Cadillac Escalade
    Edmonton
    I have the GIAC stage 2 tune plus pulley. I had the service done yesterday. I did not change my tune to stock before going in. My car "feels" slower. Does GIAC need update a tune for our cars again?
  26. #106
    Jun 28 2016
    US
    They are not going to update your and/or they're going to charge you for the update. Read the letter, it says so. Just flash back to stock and go in for the recall and then go back for the updated file flash from GIAC.
  27. #107
    Jun 28 2016
    US
    Quote Originally Posted by AdamD777 View Post
    Umm, yeah and now you're TD1 too. Smooth... hell, they might even charge you for the update once they see this. Why did you go in like that?
  28. #108
    Dec 14 2015
    Orange County, CA
    Excuse my ignorance as I don't have VAGCOM, but would a data log before and after shed any light as to what the update has modified?
    *GONE* 2016 S4, Premium Plus, BO Package, DSG, Sport Diff, Daytona Grey, CR-15 Strut Brace, EuroCode AK, 034 Trans Insert, ECS Drivetrain Inserts, 034 Rear Sway Bar, HRE FF01 19x9.5 Wheels, Brembo GT 380mm BBK, EPL Stage 1 & DSG Tune
    2020 BMW M2 Competition, M Drivers Package, White
  29. #109
    Jun 14 2015
    FRANCE
    Quote Originally Posted by Lbsigman View Post
    Hello,
    Good point.
    I really regret not have done this : before / After 24CO logs when i was stock.
    It would be really cool if a vag-com guy could do this before he has his ECM revision (and if he intends to do it .. of course)
    At least timing / IAT / A/F ratio and EGT
    BR
    Mat
  30. #110
    Mar 04 2015
    Somers, NY, USA
    At the dealer now. They're gonna do the update with my oil change.
  31. #111
    Mar 21 2015
    .....No more warranty work for you my friend
  32. #112
    Mar 04 2015
    Somers, NY, USA
    Service guy was slightly panicked when I said I had an exhaust. Must've worried I was tuned since they have to plug it in for the update. He said he hasn't heard anything outside of what the notice actually says about what the update does. Of course corporate would keep everyone in the dark if they were changing something lol
  33. #113
    May 31 2014
    Alabama
    Yea...I think I'm gonna wait this one out until we get more concrete information...
    *SOLD* 2014 S4 | Glacier White | Premium + | DSG | 034 Drivetrain Mounts | ECS Slotted Rotors/StopTech Pads | IE Intake |
  34. #114
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    they flashed it back to stock.
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
  35. #115
    Mar 04 2015
    Somers, NY, USA
    Service done. Car feels just as great as normal. Can't comment on oil temps as I don't ever look at them. But doesn't feel slower.
  36. #116
    Oct 13 2009
    MN
    Hello,
    Good point.
    BR
    Mat
    I have a VAG COM , but have never logged. I'll try and do a log tomorrow if I have time and can figure it out.
  37. #117
    Mar 21 2015
    http://www.audizine.com/forum/showth...rmance-Logging
  38. #118
    Jun 28 2016
    US
    Why would it feel slower? You're not tuned, so not much different than when you went in.
  39. #119
    Jun 28 2016
    US
    Also, what some of you are missing to understand is this. If you're not happy with what Audi did to this tune for whatever reason, then have your tuner simply put on your old file/tune and you'll be back to where you were before. They'd just have to keep track that you're on the newer OEM file so that when you flash back to stock for service, the right one goes back on. You can flash any revision of your OEM tunes that are compatible with your ECUs all you want, they'll all work. The only reason the tuners match up what you had before they flashed you is to ensure you're on the same base code for the unmodified portion of the flash (i.e. the non-tuned portions of the maps, etc.). Also, technically speaking, any tuner can easily (after getting their hands on this new file from Audi) tune it and then flash you with the new revision for both the flashed and stock files and you wouldn't even need to go to Audi, except that Audi would have no record of them doing the update on your car, so while the actual update would be applied, Audi's systems wouldn't have a record of it. Hope this all makes sense to you guys.
    For those of you with self-flashing capabilities, this is pretty much a no-brainer and you could easily get the updated file from your tuner and not even have to set foot in the dealer. The thing is, EPL already made some of these adjustments (or so is believed) to the B8.5 code, so you guys be the judge as to what you wanna do, but your best bet is to go back to OEM, go in and get updated by the dealer and then if you want to, go back to your old flash. Just discuss the concern with Tony you may have and do an ECU identify and copy/past that BEFORE you go back to your old tuned file, so you have a copy of the new flash code in case you need to go back to stock flash before your next visit to the dealer. You could do that, get them to upload you the new revision stock onto your account, but keep your old tuned one that you run on the car. Like I said before, while tuners don't really make a habit of doing this, it can be done and it'll work just fine.
  40. #120
    Mar 04 2015
    Somers, NY, USA
    Quote Originally Posted by SwankP3RF3ct10n View Post
    Obviously what the dealer said they were doing wouldn't change anything. But Bc a few posts earlier someone gave a whole Scenario about the oil temp rise (alluding to maybe Audi is doing more than they say they are to not only get rid of a CEL issue but also a melted cat issue with fueling) and how that might happen which could lead to less Power without a timing offset.
    That's why I mentioned it feels the same.
