Page 2 of 9 FirstFirst 1234 ... LastLast
Results 41 to 80 of 321
  1. #41
    Jun 28 2016
    US
    My B8 doesn't have this listed per that Audi site lookup tool. Just FYI.
  2. #42
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    Quote Originally Posted by wangshuo1989 View Post
    Got my car back, I did noticed that my car runs hotter after the ECM update. Before it usually at around 202F, today it reaches 215F..driving condition is the same. I meant engine oil temperature.
    Hello,
    Right ! I also noticed this rise in oïl temp after 24CO.
    However, i would not be too concerned about this because it's the dash displayed oïl temp, which is, in my opinion, not a mesured oïl temperature (see in VCDS/Vag Com, the label is "calculated oïl temperature").
    Maybe the changes afected how oïl temp is estimated, but not real oïl temp. Furthermore, i think that our oïl loop is not regulated in any way, so i don't see how software could allow for oïl temp changes.
    Lastly, if this temp rise is real, i don't see it as a concern, since it could fight carbon build up in a more effective way.
    What do you think guys ??
    Best regards,
    Mat
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
  3. #43
    Apr 14 2016
    2014 Cayman S, 2004 A4, 2005 4Runner
    Eastern PA
    Quote Originally Posted by yjypm View Post
    I just picked my car up after they did the update. All the vag mods are still there.
    It's like you flash your car, the vag mods don't get changed.
    Just a heads up that this wasn't the case with me. I keep noticing more and more vagcom mods that are gone.
    - Windows up/down with remote
    - Lap Timer / Oil temp
    - Steering assist disable
    I'm sure there are more I haven't noticed, yet.
    VIM stayed intact, as did no warnings when inputting GPS address while moving. Also the gear display stayed intact. (S1, S2, D1, D2, etc)
  4. #44
    Mar 05 2014
    2020 SQ5
    PDX
    Quote Originally Posted by S4Flyer View Post
    For what it's worth , when they updated the climate control module on my wifes Q5, it erased every single VagCom mod we had in place.
    She was not happy. But it's an excuse for me to buy my own VAGCom and not borrow a friends. :)
    2020 SQ5 Quantum
  5. #45
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    Another important note is for all of us living in California. If you read the back of the notice it says this update is REQUIRED for all people in CA and you need to submit proof to the DMV to get your registration. So I guess I have to do it eventually. Hopefully it doesn't screw up flashing back to APR Stage 2 after the new software is installed.
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
  6. #46
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    this is usually based on the dealer tech that runs through the modules on your car when it's hooked up
    the VAS tool will give them popups for every module it scans and say "incorrect factory coding" "re-adjust to defaults?" if they click yes, you lose your vagcom mods for whatever module it was in
    i usually ask the service adviser to kindly remind the service technician to skip the scan altogether, if it's unavoidable, i just ask him not to change revert the coding for specific modules
  7. #47
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    Quote Originally Posted by sirsycott View Post
    2nd that.
    Mike
  8. #48
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Quote Originally Posted by hyperunion View Post
    Just get the carista app.. and redo the Vag options with simple yes and no clicks
    Sent from my Nexus 7 using Tapatalk
    What OBD2 device are you using with it? Does it work with other BT OBD2 devices or just the native one?
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
  9. #49
    Markham, ON
    I've had this one for probably three years now at least initially for the torque app. No issues with the Carista app.
    Mike
  10. #50
    Apr 27 2011
    MD
    So you can use BT or wifi adapters with it?
    IG: @s4dad
  11. #51
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    Quote Originally Posted by bmoreS4 View Post
    I bit the bullet myself and ordered the Carista OBD2 adapter of amazon for $39.99. maybe could've saved a few bucks, but since ill likely use the carista app, figured I may as well have their hardware. probably not necessary.
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
  12. #52
    Apr 14 2016
    Eastern PA
    Good advice. Thanks.
  13. #53
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    Quote Originally Posted by jg 4/c View Post
    Was at the dealer today for the 35K service. They wanted to do the update. I asked if the update would wipe out my Vag mods like the one's you have.
    The SA asked the tech who works on my car. They said it would definitely wipe them out. I declined the update.
    No they are not, I can still see engine oil temp after this update. Certain update did wipe out them though.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
  14. #54
    Jan 09 2016
    Quote Originally Posted by Mat@1975 View Post
    Hello,
    Best regards,
    Mat
    Thanks for the info! I'm not too concern about it either :) It helps burn out all those moisture and gas in motor oil if it did increase anyway.
    2021 BMW 540i
  15. #55
    Veteran Member Three Rings Sean@APR's Avatar
    Feb 01 2013
    C7 S6
    Opelika, AL
    Quote Originally Posted by j1n View Post
    Im going to go APR stage 1 tomorrow. Do you think this update might interfere with flashing to stage 1?
    i received this update last week.
    You're in the states, so it shouldn't be an issue. When they update the file, we extract one and build the performance file, no big deal.
    Mat, who did you talk to over there? I don't recall hearing about this from the EU.
  16. #56
    Jun 14 2015
    FRANCE
    Quote Originally Posted by Sean@APR View Post
    Hello Sean,
    Thanks for geting involved. I will answerd you by MP
    BR
    Mat
  17. #57
    Aug 12 2015
    Minneapolis MN
    So my check engine light actually went off for this very reason at the track last month....it turned itself off randomly the next day but when I did a VCDS fault code check it was for this issue. I have a Stage 2 tune, do I risk bringing it in? Or not worry about it
    2017 Audi RS7 Glacier White w/ Black Optics
    2014 Porsche Panamera Turbo Executive Amethyst
  18. #58
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    add me to the recall 2015 S4 . It showed up on my audi page, Confirmed with AOA and dealer. Appointment Saturday AM 1 1/2 hours
    car is bone stock except for dipstick upgrade. No written notification from Audi yet
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
  19. #59
    Senior Member Two Rings Hy Octane's Avatar
    Jan 25 2013
    Just FYI.. If the dealer does flag your car with a TD1 you might not know about it for weeks or until you go in for any warranty repair.. The mechanics dont always know what is found by the scan immediately as the results go to a server out there somewhere and floats around until somebody sees it and enters it into the system. Anyway, if you have reverted to stock for this update, the tune company will have to update their files before it can be reapplied to your car.
    2013 S5 Coupe S-Tronic| Monsoon Grey | Premium Plus | Black Nappa Interior | MMI Nav Plus Pkg | Sports Diff | B&O | Advanced Key | 19" Wheels | H&R OE Springs | H&R Wheel Spacers 15mmF/ 20mmR |
  20. #60
    Jun 18 2009
    Phoenix, AZ
    Got the notice in the mail the other day, I'll get it scheduled for next week.
    2017 Camaro SS 1LE
  21. #61
    Aug 12 2015
    Minneapolis MN
    Quote Originally Posted by Hy Octane View Post
    Tune company as in APR or the dealer that does the tune? So to get re-flashed back they need an update from APR?
  22. #62
    Nov 28 2015
    Montreal, QC
    got the letter.. from what i can see. this update brings me nothing good just potential problems with TD1 or my tune. Or am i missing something here ? I will just ignore this recall. ( not to mention, i never got the warning and I don't need to pass an emission test over here)
    S4 B8.5 no track, just enjoying spirited driving.
  23. #63
    Established Member Two Rings Siopao's Avatar
    Aug 22 2016
    2019 A7 2021 Q7 (wifey)
    Houston, TX
    Quote Originally Posted by waxxonMTL View Post
    I'm feeling the same way....are we really going to mess our cars up if we don't get this software update?
    Thanks
    Paolo
  24. #64
    Jan 09 2016
    Update, I got another issue after getting this recall. My engine oil temp will fluctuate (like goes to 170 and immediately goes back to 168, then goes to 170 again, and it happens all the way to 200), that's something I've never seen before. Car drives normal though.
    2021 BMW 540i
  25. #65
    Aug 22 2016
    Houston, TX
    Hey Wang,
    So does that mean don't do it???
    Thanks,
    Paolo
  26. #66
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Got this today for my 2014 6MT that I no longer have . It specifically states, IMPORTANT! Please note: that if the ECM in your vehicle has been "chipped," "tuned," or otherwise modified from original factory specifications with aftermarket components and/or software, work needed to repair, replace or return the ECM to original factory specifications is NOT covered under this action" Certain Model year 2102-2016 MY Audi 3.0L TFSI Engine Vehicles. So it would include both B8 and B8.5 cars
  27. #67
    Mar 21 2015
    ^ I Think everyone saw that on the pic of the letter
  28. #68
    Aug 22 2014
    bloomfield,ct
    Quote Originally Posted by jygesq View Post
    got letter today , put off getting done for two weeks to see if any adverse effects from software update.
  29. #69
    Mar 21 2015
    I haven't got the letter yet but I need it done. Im waiting too to see the outcome.
  30. #70
    Veteran Member Three Rings AerotusX's Avatar
    Mar 24 2014
    Hey Sean, I just got this recall letter in the mail a couple of days ago. I have APR Stage II tune. So, are your saying it's okay for me to flash back to stock, do the ECM update, and then flash my Stage II back without any issue? Thx!
    2015 Audi S4 Prestige | DSG | Moonlight Blue Metallic | Black/Magma Red Fine Nappa | Sports Differential | ADS | Aluminum/Black Wood Inlays | 19x9.5 VMR V710 | XPEL PPF | 3M Crystalline Tint | KW H.A.S. | Vag-Com | CR-15 | Alu-Kreuz | APR Stage II | APR CPS | RS4 Grill | Eurocode Sways | Eurocode Inserts | ECS TCU
  31. #71
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    Just FYI, for those that concerns about flashing back to stage 2, I had no issue on this.
    Flash back to GIAC stage 2 without any issues.
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
  32. #72
    Jun 18 2009
    Phoenix, AZ
    I'm really confused as to how this update would affect oil temps. Maybe they have leaned out the a/f mixture some, causing higher EGT's and a warmer engine overall?
    2017 Camaro SS 1LE
  33. #73
    Mar 04 2015
    Somers, NY, USA
    Quote Originally Posted by FWP! View Post
    Agreed ,,it's supposed to do with diagnostic thresholds for the cats. Maybe the temp stays the same but is being calculated differently.
  34. #74
    Jan 09 2016
    Quote Originally Posted by Siopao View Post
    Hey Wang,
    Thanks,
    Paolo
    I'll put more miles on it and see if it goes away. If not, I wish I didn't do this update...
    2021 BMW 540i
  35. #75
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    That's a possibility, can someone log their car please and post?
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
  36. #76
    Mar 24 2014
    Quote Originally Posted by yeuchau View Post
    That's good to know! After reading Mat@1975 post about his issue, I was a little concerned.
  37. #77
    Jun 17 2016
    Florida
    Wow dipstick upgrade major moves
  38. #78
    Dec 16 2012
    SF Bay Area
    Quote Originally Posted by creativecody View Post
    This worries me. Sounds like the programming change is substantial and may affect performance. If it were just a change of a threshold to a more permissive value, why would DMV care? The fact that some people see higher oil temperatures after the ECU update, if true, confirms that the programming change affects engine operation significantly.
  39. #79
    Jun 28 2016
    US
    Quote Originally Posted by audiBMWfan View Post
    Because it has to do with the emissions system in the car and we all know how Cali is about them apples.
  40. #80
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    A catback and intake shouldn't be a problem?
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
