Results 1 to 14 of 14
    Veteran Member Three Rings TagEldinAhmed's Avatar
    Dec 06 2015
    Los Angeles, CA
    WTB: Silver S-Line Front Bumper & Trunk
    I'm looking to buy a front S-Line bumper and S-Line trunk in silver. I need all the parts that would be necessary for the conversion from a non-SLine with the exception of a grill (that's optional).
    Let me know if you've got anything available, thanks!
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    You definitely will need an S-line grille if you upgrade your bumper, the two are not interchangeable
    2007 Porsche Cayman | 5MT
    Dec 06 2015
    Los Angeles, CA
    Quote Originally Posted by Ashtonts View Post
    Oh, I know. I just meant that I could purchase one myself from anywhere else since the seller might not have it, might even go the RS/Honeycomb grill route anyway.
    Jan 17 2015
    Quote Originally Posted by TagEldinAhmed View Post
    Ahh gotcha. Can't really beat the honeycomb, that's for sure!
    Veteran Member Four Rings brandonpham's Avatar
    Dec 07 2014
    Belleville, NJ
    I can maybe get you a refurbished primered S Line front bumper for $275 shipped.
    Jul 26 2013
    Arizona
    Don't forget the rear valence and door blades to complete the look (though some non s-line vehicles have textured blades)
    I've got a rear valence on black that I replaced for quad tip valence
    Dec 07 2014
    Belleville, NJ
    Quote Originally Posted by nnlugo View Post
    I believe the rear bumper itself is also different so he cannot swap the valence.
    Jan 17 2015
    Quote Originally Posted by brandonpham View Post
    The S4 valence can be swapped onto a regular A4 bumper. There's no difference between the S-line, and non S-line rear bumper AFAIK
    Dec 06 2015
    Los Angeles, CA
    A bit too much considering I'd still need to paint it :/
    Jul 26 2013
    Arizona
    B7 rear bumpers are the same for the A4 and S4, with the exception of DTM and RS4, I believe.
    The s-line valence and S4 valence can both be swapped with the non s-line basic valence. I've had them each over time, running the S4 with quad tip at the moment
    Dec 06 2015
    Los Angeles, CA
    Completely forgot about the door blades, I need some S4 ones in silver as well. As for the valence, I'll eventually get a CF one once I get an exhaust.
    Jul 26 2013
    Arizona
    Some guys run s-line blades up front and s4 in back, if you're into that
    Dec 06 2015
    Los Angeles, CA
    Nah, I like the aggressive look of the S4 ones.
    Dec 06 2015
    Los Angeles, CA
    Bump?
