Results 1 to 40 of 43
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Logs: Non-Meth vs. Meth on a Dual Pulley 3.0 TFSI
    This came up on the Facebook group. Someone had asked if meth injection was better than an upgraded heat exchanger/coolant system in terms of battling IAT's. The short answer is no, it does not do as much for IAT's, but it is slightly beneficial in other ways. I've posted some logs below. The IAT drop is maybe 2-3 degrees C at best with meth (the AMS/Alpha coolant system drops temps by 2-3x that amount in similar conditions).
    The vehicle in question is an EPL/E85 tuned (running E70ish), 2010 DSG S4 running an 189mm crank pulley with APR SC pulley. Roc-Euro intake, JHM test pipes, and AMS/Alpha coolant system. Ambient temp was prob 85F and 2500 DA (high this day was 98F degrees).
    These logs were done on back to back passes. As you can see, the "meth on" logs were done first, and the "meth off" logs were done at the end. Take that into account when considering the temp differences. Also, note that his car shifts at 6700 rpm....
    Meth on 1st pass:
    Meth on 2nd pass:
    Meth off:
    At 66xx RPM:
    IAT (C): 57C (off) vs. 55C (on)
    Boost (psi): 17.7 psi (off) vs 18.3 psi (on)
    Timing (degrees): 25.5 (off) vs. 26.625 (on)
    No bypass on either, but there was a little knock correction (1-2 degrees) at 6400 RPM with the meth off.
    What are we talking about? This is injecting a 50/50 meth/water into the intake tube. In this case an AEM kit with 1000cc nozzle (he's also tried a 500cc nozzle) triggered off boost. It's injected pre-SC because that's the only way for the factory pressure/temp sensors to see any difference. Ideally, you'd inject post-SC to get a much larger benefit in terms of temperature reduction, but that would be downstream from the pressure/temp sensors. Injecting post-SC would provide some extra safety margin, but no performance benefit unless custom tuned for it.
    The downside to this type of setup is the meth/water runs through the SC which is essentially a large heat pump. This negates a lot of the temperature related benefits. On the plus side, it slightly raises boost, and helps with fueling by unloading the injectors a little (he's able to up the ethanol content to over E70).
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    Love this post. Thank you for sharing.
    What if it was stacked with an HX? Overskill? Redundant?
    HX, Meth, "Chiller".... The perfect combo will happen
    '18 S5 - BBS / EPL
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by JD S4 View Post
    He had both, so I can't really say. Maybe it'd have a slightly larger effect on a fully stock cooling system? I think his plan is to add some type of additional cooling system like the Killer Chiller (or something that uses the AC system for additional cooling).
    Stage 2 Banner Advertiser Four Rings
    Sep 06 2007
    Looks great!
    I'd love to see logs with more water and less meth!
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by Tony@EPL View Post
    Looks great!
    Yep, looks strong. I'm sure he'd be willing to do that if he hasn't already.
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    I'm not good with reading these things but I would have thought the iat's would have been significantly lower w/ the meth set up compared to the non meth set up at rpm's above 4k. What part should I be looking at in order to realize how special this set up is? boost?
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Great info! Sucks that the meth isn't helping more, but like you pointed out, he gained .6 psi of boost, had a bit more timing and there wasnt any timing being pulled up top.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by Thurston View Post
    You'd want to look at the iat's, the actual ingnition and the knock correction columns
    May 22 2015
    DFW
    Looks great!
    Ask and you shall receive! I'm almost thru this batch I mixed. I'll get with you on this soon.
    Jun 12 2015
    CA
    That's really temping. I just don't know if I want to make a commitment to keeping the meth tank filled all of the time.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    There are obviously a lot of variables that impact performance, and some of those are captured here. Boost, IATs, timing, knock correction, and bypass are the main ones shown. You kind of have to take them as a whole in terms of how it effects overall performance (one reason I provided a summary at the end). You could look at others that may provide some insight that aren't logged here: air mass, EGT/lambda readings, fuel trims, etc.
    I posted this because someone had specifically asked if meth was more beneficial than an upgraded heat exchanger, and several people said it was or something along the lines of they had seen a 20 degree drop on another platform (which won't happen here). I think the take away is that it is beneficial in some ways, but not purely in terms of IAT's compared to some other platforms (or a good upgraded heat exchanger on this one).
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Agreed, not much help with IAT's. Wonder how significant those deltas are though given that meth was off on the third pull... These DP cars generate heat! But those IATs look very good though in that ambient temp. I'm a bit jealous lol. E85 FTW! Thanks for sharing
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Nice post. Really answers the lingering questions whether to meth or not to meth .
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Apr 27 2015
    canada
    jran I totally missed your summary at the bottom. thanks.
    Jul 12 2016
    UK
    Thank you for the post. My main reasoning for looking at meth is the cost. With my old platform, folks were seeing crazy temp drops, but that was from a turbocharged engine. I just think the cost of these coolers you can buy are expensive in comparison to a meth kit.
    What sort of differences are we looking at with the stock cooler vs an aftermarket then? Does it justify the cost or is it better for me to go straight for the MRC package?
    *I don't have access to E85 before anyone recommends it.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by mrmomo313 View Post
    Yes, E85 does help temps no matter what anyone says. We're going to try and dyno the cars again on Monday, and i'm guessing andthen will see the same or better temps than my non-dual pulley car (we have the same coolant system).
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by GoatMasterUK View Post
    My car averaged around 10C drops with the AMS/Alpha system. A lot there depends on the how you capture the data. I did 6 back-to-back 3rd gear passes on the same road in the same conditions when I logged. Obviously as the car gets more heat soaked, you see a bigger benefit. By the 6th pass, I was seeing 10-12C lower IAT's.
    The cost for some of the systems isn't bad. The PLM kit is $800 (USD), and the Revo is going for $930 through a group buy on here. Prices may vary there though. I'd recommend something with a larger heat exchanger at a minimum, and the largest reservoir you can get next. A pump would be next on my list, and then something that divorces the coolant loops last.
    Veteran Member Four Rings 613B6's Avatar
    Jul 29 2009
    Street racing in Ottawa
    I run an AWE HE and AEM meth kit, I added a second nozzle lately on the intake tube, the other is on a TB plate. I now inject 1250ml/min total and that's where I saw a huge decrease in IAT's across the delta. On a 57/190 combo I only see approx 30 degree change across 1-4 gear WOT pass even in extreme heat at the strip (went 11.6@117 on pump/meth). As noted, the blower is sucking up a lot of the mix however is almost enough to allow me to run the monster GIAC race file daily. I know with APR having less timing in there race file, S4matty is running meth and race file daily on pump.
    A3 8V | 10.89@129 | Boss700 | Eurodyne
    Jul 21 2004
    South Florida
    Thanks for posting the results Jran!
    I am surprised as well that it didnt do more but can see spraying pre-SC is likely eliminating alot of the possible benefits.
    Still, there was no knock seen on the meth runs so it is hard to tell how much timing the tuner could add to that car running meth to give it more power. What it does show, though, is that the meth runs have room for more timing (more power) and the non meth runs do not.
    Would be interesting to see what spraying post-SC with custom tuning that does an offset on the IAT sensor would produce. As long as you monitored knock there could be some more gains there too.
    Boost season will be interesting. Plenty of room left for power it seems, which is great.
    Mike
    2018 Audi S5
    Gone-
    Sep 06 2007
    The logs posted are are great data point... But i think its safe to say that the delta gains on a pump gas car would most likely be larger then this dual pulley e85 car.
    Water/Meth is awesome of 91 octane cars that dont have access to e85 to mix!
    Jul 12 2016
    UK
    I use 99 here in the UK. No idea what that equates to over the pond.
    Jul 12 2016
    UK
    Quote Originally Posted by jran76 View Post
    I've seen some systems for almost double that. Would the cooler be worth getting before the map? MRC are quoting 500 PS and 600nm..
    Jul 26 2014
    First of all, thanks for the great data.
    I would be interested however to learn more on the cited part. The way I see it, the benefit from injecting upstream to IAT sensor and hence making it "see" the IAT reductions is that if you have any IAT-related corrections (firts of all ignition angle, but probably also boost) they may be cured. Based on the logs above I can't really see more aggressive timing with using W/M however, what I see is that the boost without W/M is (other things equal) slightly lower leading to higher base ignition angle which proves to be a bit more agressive and results in slight knock retard, leading in the end to essentially the same actual ignition angle.
    What I'm trying to say is that while on the first glance it looks like W/M gives extra octane (hence no ignition retard) in fact it rather gives extra boost here (well, then possibly extra octane as well since who knows what would be the ignition retard at such boost with no W/M ).
    With this in mind I'd say that inject post-charger (in hot air) and pre-charger (cold air which will then be heated during the compression process) would both result in lower IATs as W/M mist evaporation to take out heat will occur in both cases in a similar manner. However, injecting pre-charger is also known to alter the air compression physics (in theory) leading to more efficient compression process and more airflow, which is not the case when you inject post-charger. With more boost based on the above logs I'd say these charger efficiency gains are seen here, and could be probably higher in case of higher W/M flow or more water in W/M mix. So in the end, injecting pre-charger in this application is probably even more efficient than post-charger. Thoughts?
    2011 S5 Sportback
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    Quote Originally Posted by -leman- View Post
    Would logging MAF along with these logs be a good indicator of any increased efficiency due to the cooling effects pre charger?
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
    Nov 10 2014
    Apex, NC
    93
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Quote Originally Posted by Older_not_Wiser View Post
    No because we do not have a MAF
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Jul 26 2014
    As correctly pointed out above 3.0T engine does not have MAF, so air mass is a calculated value. But, seeing slightly more boost and even a fraction more ignition angle at the same engine speed (which is seen in above logs with W/M on compared to W/M off) should give you higher calculated air mass.
    So I'd say logging air mass would be still an adequate indicator of increased efficiency, it would not be "real" value seen by dedicated sensor but it would save you hassle trying to deduce the air mass based on the other sensors "real" data available. A kind of workaround approach.
    2011 S5 Sportback
    Apr 01 2016
    E38 750IL, VW Polo 1.2TSI
    India
    Has someone tried the cryo2 intercooler sprayer kit, lot of Evo guys are using it with great results?
    Sent from my ONE A2003 using Tapatalk
    Jun 28 2016
    US
    Quote Originally Posted by eklavya View Post
    And along those lines, what about this thing?... https://www.designengineering.com/ca...yo2-air-intake
    Sep 06 2007
    Basically the same install as a basic dry nitrous kit... requires a blow down tube to run at the track (involves drilling a while in the the truck floor).
    If you were going to go this route, I'd just run a single nozzel ~35-50 shot set up.
    Apr 01 2016
    India
    So you think it is worth a shot?
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    I mentioned this in another thread, but the plan is for andthen to add an additional nozzle like some others have done, and re-log. That would be spraying 250cc just after the intake filter, and then 1000cc at the throttle body. Right now he is just spraying 1000cc after the intake filter. I'll update accordingly....
    Feb 25 2014
    Texas
    How come andthen doesn't post anymore?
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Jan 04 2013
    Phoenix, az
    I would think that the intercooler chillers would work more on our cars. think about how long the water is in contact with the cooler vs how long air is in the intercooler on a turbo car. Seems the impact would be great with the way the system is designed on our cars.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by AudiS4B8 View Post
    I think he does, but he's just been busy. He had a post above....
    Quote Originally Posted by cspcrx View Post
    There are at least a few people going this route, so you should see some data soon. The preliminary data sounded really good....
    Jan 04 2013
    Phoenix, az
    Interested in seeing those results. Just makes sense as a way to super cool it before you run. Also, you could pop the door which would get the pump running and circulating the fluid through the charger and cool that off as well.
    May 22 2015
    DFW
    I'm still lurking around, it's just been way to f-ing hot here in Texas to do much with the car. Been working with Tony on my 189mm FD and Meth tuning a bit lately.
    I tried more water and less meth today and it was a shit show. 1000cc at 33 percent meth and 66 percent water. IAT went up over 30 degrees in a single 3rd gear to 4th gear highway pull. Too much steam I think. Roots blower is turning out to be a tricky thing to spray meth into. I drained the tank and will mix up a new batch soon. Definitely thinking I need to spray more volume and dare I say less water..
    Jul 26 2014
    Theoretically adding more water should get your IATs down (because higher heat capacity of water vs. meth) while more meth should improve knock tolerance (because higher octane, but then I understand that your runs were on E85 so the knock suppression effect of meth is unclear if any).
    It's interesting to see that in practice it all works the other way around...
    2011 S5 Sportback
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    What are you guys using, Boost Juice?
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    May 22 2015
    DFW
    Quote Originally Posted by RWD2quattro View Post
    I buy straight 100% meth and mix it myself.
