SOLD
Up for sale is my brother's 2005 A4 1.8t Quattro with brilliant black exterior and Tan interior. Car as mentioned is a 1.8t Turbo 4 Engine with a 6 Speed Manual Transmission and Quattro All wheel Drive. The car has 133, 536 miles on it with the major services done to it. Below is a list of what the car needs or wrong with it, and what has been done maintenance wise. The AC Blows cold the sunroof works and doesn't leak has heated seats in the front for those cold winters, and the driver side seat is powered. Besides what is needed below There is a scratch and dent on the front drivers side fender and a little on the bumper and a scratch area on the rear bumper, bother of these where from the previous owner. Car Fax is clean accident wise and the wheel alignment was easily done indicating no frame damage. The car has been his daily commuter car and he is buying a new car so I need this gone. Price is 2750 obo (Or Best Offer).
Maintenance Preformed:
Synthetic oil change using Shell Rotella 5w40
Full timing belt service kit using OE parts w/serpentine belt
Serpentine belt tensioner
Coolant bleeder Schrader valve
New OE Luk Clutch and flywheel (Including the Pressure plate, Clutch disk, throw-out bearing, Pilot Bearing, and Flywheel)
Front Right Strut mount bushing
Both Front right lower Control Arms
Front right outer CV boot
Both left/right inner and outer tie rod ends
4-Wheel Alignment
Exhaust mid-pipe replaced
Front brake job using Zimmerman rotors and textar pads
Needs:
Driver side front Window regulator
2 tires. Currently mismatched tires
New Glovebox Door. Still have the old one for the lock cylinder to match the key. Bought the car with broken hinges on the panel. (very Common with 2002-2008 A4/S4/RS4 Models).
email [email protected] Cell 973-906-1159
