Results 1 to 3 of 3
    Aug 08 2016
    Replace front and rear end links or just front
    Going with blisten B14 Coilovers and for sure new front end links. How important are the rear end links? Anyone know if the stock rears are OK to leave on with coilovers? I won't be tracking the car it's just my DD.
    Veteran Member Three Rings INYAUDI's Avatar
    Feb 21 2016
    Southern New Hampshire
    They are fine for DD with bilsteins. You'll probably have them on your list of parts to upgrade once you see what they're made of
    Follow my build on Instagram: @towknee603
    Instagram: TonyConQuattro
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    Simple......IF you are changing out the OEM sway bars then....YES I would highly recommend to change them...otherwise leave them in. The oem links...especially the fronts are very flimsy.
