Results 1 to 40 of 40
    Junior Member Two Rings
    Jan 16 2016
    Some questions about Drive Select
    I have a '15, MT S4. I was hoping some people here could enlighten me a bit about the drive select modes and what they actually do. I usually keep it in either Comfort (driving with the family) or Dynamic when I'm by myself. I definitely notice a change in the suspension when I switch to Dynamic - but are there other changes as well? I could swear that I feel the a bit more power when I'm in Dynamic mode, but not sure if it's mental or not. Also I was searching around a bit and saw some posts where people are talking about fake engine noises coming from a speaker, etc for different modes. Is this actually true? It seems kind of lame to me, but now that I think about it, the engine does seem a bit nosier in dynamic mode. So is there any truth to that?
    Thanks,
    h
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    If you have the dynamic suspension and sports diff then they obviously change along with the steering. And what you is the "Soundaktor" with is the simulated engine noise through the speakers. It's louder when it's in Dynamic.
    Active Member Two Rings Audiraz's Avatar
    May 19 2016
    Colorado Springs co
    Yes!! Pull out fuse #5. Then you will hear the differance. I never put it back in, and just replaced the resonators with an X pipe. I love the car my sound makes naturally! But if you are the kind of person that is happy with fake boobs, just leave it in. But at least you can hear the difference and decide for yourself.
    As far as the drive select, cycle through until you get dynamic again. You will notice an S with the current gear selected. Sport mode is a beast! It will never go past 6th gear and will hold the shifts longer. Everything is a bit more responcive. As for the other modes, just do a quick google search. Or read your manual. It explains them all.
    May 19 2016
    Colorado Springs co
    Scratch that last part. Just saw that you have a MT....
    But still pull fuse #5!!!
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by Audiraz View Post
    it will go to 7th when you engage cruise.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by s4tress View Post
    I keep mine set as:
    Engine/Trans: Dynamic - shifts just like I would in a manual holding gears just long enough but not too much.
    Steering: Auto - I like light easy steering in parking lots and how it will stiffen up on the freeway
    Suspension: Dynamic - unless I'm on a 2hr or so highway cruise, then I put it in comfort
    Engine Sound: Comfort - just a little intake noise through the speaker and that's fine. most realistic IMO
    Sport Diff: Comfort - unless I"m at the track - Comfort is Audi's "Safety" setting.
    I keep the sport diff in comfort as after talking with then visiting Audi's VA offices, one of their Customer Service Reps explained and showed me how the sport diff will actually protect you from oversteer and lifting. It's actually a pre-stability control safety net on our cars. Very cool especially on surface roads that are no where near as predictable as the track. I especially keep it set in comfort mode in the winter when the roads are bad.....unless I want to be a hooligan and jump off a light with my ass hanging out. Go Stage II and you'll see what I mean.
    My story on the Sport Diff in comfort mode is seen daily as the entrance ramp to our freeway is a right turn that takes you up slight elevation a bit then drops down as you enter the ramp to the freeway. just enough to shift the weight of the car at speed upwards. When it rains and in the winter there are cars off to the left daily LOL. I hit that ramp one time entering way too fast and in Dynamic mode, I was that ass-hat that had his rear end hanging out with a slight pucker factor in my pants as I really didn't expect it, but thankfully the car rotated and the AWD and stability system just shot me down the ramp. Now with the above settings if I do that, the car still rotates but not nearly as much...perhaps 1/2 as much, before the systems kick in and point me down the ramp. Very noticeable and now to me predictable comparison of handling. It's one of the best ramps to show physics of a 4,000lb car dong a lateral slide even with Pilot Super Sports on.
    Here's a shot of the ramp: The turn-in is actually a lot sharper than it appears in the google street view pic.
    Mar 21 2015
    Your manual in the glove box will give you some insight.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    The "more power" you feel while in Dynamic mode is really an illusion. The Dynamic engine mode remaps the accelerator pedal so that it gives more throttle with less input. Power is still the same, but in Dynamic mode something like the first 25% of the pedal travel gives like 75% of throttle input. Those numbers are made up, but just trying to give you an idea of what is happening.
    Nov 27 2015
    UK, West Berks
    Quote Originally Posted by pdqgp View Post
    Interesting. Despite the fact that I live in the UK I have yet to experience my S5's sports diff on really wet roads. I shall bear your comments in mind. IIRC I have it set to auto/balanced in individual, but of course in ADS dynamic it is dynamic setting.
    To the OP: If your car has the dynamic steering then ADS also changes the ratio. It makes the steering light in comfort and sensitive in dynamic. And as I think was already mentioned, ACC changes with ADS setting too.
    2015 monsoon grey S5 sportback (yes the one with 4 doors)
    - MRC stage 2 (189mm Vdamper/Fluidampr crank pulley)
    Veteran Member Four Rings theedge111's Avatar
    Apr 15 2009
    Calgary
    Why are you here if everything posted on the site upsets you so much?
    Veteran Member Three Rings chopz33's Avatar
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    what this pulling of the fuse #5 talk?
    whats that all about?
    2012 S4/ Prestige/ Black Optics Package/DSG/Red Leather/B&O sound
    KW HAS/RS4 grille/LED conversion/USP Intake/AWE Touring-resonated DP's/034 trans mount/Niche Stacatto 20x9/CF Stvbek front lip/Unitronic Stage 2 ECU/TCU/ECS CF diffuser/CR-15 Strut brace
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Quote Originally Posted by chopz33 View Post
    It disables the "Soundaktor" which produces fake engine noise thru the speakers. The proper way would be to disable via VAG-VOM
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    Would this be something I would notice and would exhaust be louder. I have awe exhaust
    Sent from my LG-H820 using Tapatalk
    Sep 20 2006
    MD
    Definitely noticeable. Give it a shot.
    Jan 28 2013
    That's because when you have cruise control enabled the transmission switches to Drive mode.
    Mar 01 2016
    Gone: 2007 Acura TL Type S, 2004 Acura TL, 2005 VW Passat 1.8T
    NH
    I keep mine set as:
    Very well described pdqgp, I know the exact feeling you are describing, and experience it pretty often myself. I personally keep my sport diff in sport but traction control in sport and notice similar behavior, but I can see that if I had more than stock power where the Dynamic setting of the diff might be counter productive as a safety net.
    2013 S4 DSG | VX3 LED Fogs | LED interior conversion | LED reverse lights and plate lights | CR-15 Strut Tower Brace | 35% Window Tint |
    Mar 21 2015
    Quote Originally Posted by theedge111 View Post
    I was not upset but apparently you are by my post. The manual will tell him everything about it with pictures so therefore is relevant. Why don't you keep to yourself.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by jsh139 View Post
    Are you positive that's the case? Because if so, it seems that I should be able to get the car to accelerate just as quickly by mashing the pedal in comfort mode as it would by going, say, 50% throttle in Dynamic. But in comfort mode the car just feels sluggish. It feels like it's more of a time delay thing, like in comfort mode I can mash the pedal all I want and it will just delay the amount of throttle movement that actually happens, resulting in more gradual acceleration.
    SOLD 2015 Daytona Gray S4
    Jan 12 2010
    SE Pennsylvania
    [QUOTE=pdqgp;11902421]I keep mine set as:
    This explanation, imho, is backwards and a bit misleading.
    The benefit of our sport diff is that it mitigates the inherent understeer of a car with most of its weight over the front axle and 40f/60r quattro torque split.
    To create more rotation, livelier dynamics and "fun", our sport diff is great.
    With the sport diff off, the S4 will understeer more like a fwd car (some people refer to this as plowing).
    So, it's not that the sport diff is a safety net when off, only that when off, the S4 has more understeer than oversteer.
    The different handling dynamics are always a trade off between fun to drive (oversteer) and dull (understeer).
    If you overcook a corner with the sport diff off, you could end up plowing off the road as the front tires and steering could not correct the car's line in time.
    So in the specific situation you experienced, the combination of too much speed and an unexpectedly sharp curve (and with negative camber) could end up being bad either way.
    Glad you reacted fast enough to stay safe.
    2014 S4 Prestige l Misano Red Pearl l Black Alcantara l DSG l Sport Diff l Carbon Inlays l 034 Solid Rear Sway bar w/ Moog End Links l Eurocode Trans Insert l ESC Rear Diff Inserts l CR-15 Strut Tower Brace l Uniden LRD 950 Mirror Tap l Chipwerke Pro
    Previous:
    1994 Ford Taurus SHO w/Yamaha V6, 5 Speed
    1999 Ford Mustang Cobra Convertible, Triple Black, 5 Speed
    2007 BMW 335i 6 speed l Tuned
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    a review of the info provided by Audi suggest comfort mode is the most stable mode for sport diff.
    Steve you have 6mt . Us with DSG find different experience on acceleration. I find in S mode the shift points are at higher rpm. but throttle response is not much different. Maybe because DSG learns drivers inputs. I give it gas in D and depending on where I push the pedal car really moves, thrusting you back into to your seat.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by 4wheelpilot View Post
    You're welcome to your opinion, but it's not misleading at all. With the sport diff in Dyanamic mode and all safety systems still engaged the car will rotate more than it will in comfort mode. I'm simply showing through an example of how on the daily roads we all drive that there's a difference and what it is. Call Audi if you wish to have them explain the safety net scenario to you and how Comfort mode differs from Dynamic mode as they did a great job of explaining why it's safer for drivers in inclement weather to use Comfort vs Dynamic.
    Reaction wise, my steering input was / is the same, it's just the car allows for less dynamic rotation or "fun" but still saves your bacon and allows the driver to point the car where it should go. Especially useful in every day driving where one is not intentionally hitting curves with enthusiasm or has room to cross over a lane. As they explained it, the system under comfort mode will also react differently should a panic situation occur and the driver were to lift mid-corner as might happen if hitting an exit ramp too fast.
    Again, I'm not the best at explaining it but the call center did a great job and it was cool to meet the team in their VA office when I was there. Several of them that I met were very much enthusiasts. It's great knowing that the car has a mode for all out fun on the track and also a much more conservative setting that allow for fun yet safety on the street.
    Apr 05 2012
    Earth
    The Soundaktor doesn't produce fake engine noise through the speakers; that's how BMW's system works. The Soundaktor is a speaker mounted against the firewall which uses the windshield and firewall as an amplifier for it. The sound it emits is the actual sound of the engine just that it's amplified through the vibration of the windshield and firewall.
    Jun 28 2016
    US
    My daily settings are:
    Engine/Trans - Comfort
    Steering - Dynamic
    Diff - Auto
    I will flip to Dynamic for all modes with one push of the ADS button on the dash when needed, which flips the engine/trans and diff to Dynamic. I like the stiffer feeling of the wheel in Dynamic, which is why I always keep it in that. The idea behind keeping my Diff in Auto is that when I'm not pushing the car, it'll feel fine and neutral, but if I need to push it, even if I haven't flipped the engine/trans yet to another mode, the Diff will flip to more Dynamic feeling and rotate the car as intended. Keep in mind that having the engine/trans in Comfort doesn't change the output of the power available, just the ramp up and response of it, so for those of you who putt around with the Diff in Comfort, you might have well just bought a non-sports diff equipped S4 because you're just not really using it or allowing for the system to kick in and be used if you need it. Maybe I'm just more of an aggressive driver than those people are, but there's a reason Audi calls the Comfort mode for the sports diff "their safety setting"... cuz yeah, it'll err on the side of understeer rather than oversteer. And here's the thing... even oversteer on this S4 with the diff in Dynamic is so silky smooth and predictable, you really can't fuck it up... well, you shouldn't, but I'm sure someone out there probably can. hahaha
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    if i have AWE exhaust, by pulling the soundaktor will be car be louder in the cabin or quieter. i dont want it quiet.
    Jun 22 2016
    West Chester, PA
    The Comfort Mode is another name for Better-fuel-economy-driving Mode. The gears switch up quicker while maintaining really low RPMs resulting in slow but gradual acceleration...which is why you feel sluggish performance.
    While in the Dynamic Mode, two things happen to the transmission:
    1. The RPM of the engine gets pushed higher (close to 2200 maybe?) than its Comfort Mode (close to 1200 rpm).
    Result: You hear the engine roar louder
    2. The gears switch up slower which means you stay in the same gear for a longer time than the Comfort Mode. (The downshifts are a bit rough though)
    Result: You find the engine to be more aggressive and responsive. In other words, you reach 0-60 much faster and a grin shows up on your face.
    For my daily driving style, I put everything to Dynamic except for Steering and Transmission which are both set to Comfort.
    For my highway driving, I put everything to Dynamic. Once I reach a constant speed, I pull the gear lever down, once, and switch it to D instead of S. If I have to overtake or do some revs, I pull it down again and I move to S from D. To each his own :)
    2016 S4 Sepang Blue Premium+ | Black Optics | B&O Tech Pack | Sport Diff | ADS | Black Nappa
    CTS Intake | Alu Kreuz | EBC Red Stuff | 034Motorsport Dynamic+ Springs | CR-15 | Vorsteiner VFF-103
    Build Thread
    Jun 28 2016
    US
    You have a 2012, so that doesn't even pertain to your car. Soundaktor is only in B8.5 (2013+) S4.
    Jun 28 2016
    US
    Quote Originally Posted by absolutarin View Post
    The ramp-up of the TPS input is also changed between Comfort and Dynamic.
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    Quote Originally Posted by SwankP3RF3ct10n View Post
    Haha good deal.
    Jun 22 2016
    West Chester, PA
    Yes. That too. Thanks for mentioning it
    Build Thread
    Mar 06 2015
    Columbus, Ohio
    It won't understeer in comfort mode. I drive aggressive in curves and it rotates nicely. Agree that it's hard to fuck it up though. My favorite turn around here is a sharp left turn onto a secondary road near my house. I nice stab of the gas and you can feel the car push the rear end on the outside more and it just scoots around the corner. Very cool feeling. I've done it in dynamic mode too but it's easy to end up with your ass end in the other lane which I don't want. Here's a link to a great write up on the systems overall. It's in pdf format. This has been out there for a while but the call center emailed this link when I first called into to ask about the various settings when I g
    Mar 06 2015
    Columbus, Ohio
    quieter but IMO it will likely sound crappy with the soundaktor on. you'll have noise coming from both the front and back. keep it out back and let the SC Whine thrill you up front.
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    Quote Originally Posted by JohnEnglish View Post
    I think that this is how Soundaktor works in the Golf R, but in our S4 it's using the sound system completly.
    Murdered B8.5 S4
    Build Thread
    Aug 22 2014
    bloomfield,ct
    Quote Originally Posted by silverf0x View Post
    I do not think you are right. I hear no engine sound through my car audio system.
    Apr 05 2012
    Earth
    No, just search Google for Soundaktor S4. You'll find a lot of photos and videos showing its location and how to remove it.
    May 10 2012
    2013 s4, 2008 cbr1000rr
    United States
    On the topic of fake boobs, if you can touch them, then they are real
    Dec 14 2015
    Montreal, QC
    Quote Originally Posted by jygesq View Post
    I was thinking this because I remember, some time ago, seeing a company that "hacked" the Soundaktor to simulate Lambo/Ferrari sound (and no I'm not talking about the SoundRacer product). So I kinda deducted my conclusion from there. Sorry if I'm wrong.
    Murdered B8.5 S4
    Build Thread
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    This is not correct......although that may be a mechanical part to the equation, there's a lot more going on with the shift points etc.
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by SteveYem View Post
    That is what I have read on here and that is what I experience in my car (even when it was stock). Mashing the pedal in any mode produces the same results. I feel like I remember reading that some people even drag race in comfort mode?
    Quote Originally Posted by Crucible35 View Post
    I probably should have clarified. I was speaking from a manual trans POV. The OP has a manual trans so there's no auto shift points to worry about.
    May 10 2012
    United States
    The pdf just left me wanting more information about comfort vs dynamic and the changes in car characteristics in a corner.
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by DBL R View Post
    track it and see first hand
    or drive that baby around some remote roads of Mexico.
