Hey guys,
I finally got rid of my open element hot air intake in lieu of a stock airbox -> 85mm MAF -> cts turbo rs4 elbow setup, which solved a ton of MAF issues / codes.
During the initial log on stock timing maps / safe boost PID... this was the fueling result:
After a revised tune and another log (might not be long enough, ran out of room), it seems like there is a larger discrepancy between the requested and actual:
Could the stock airbox be a point of restriction causing the requested boost to not be met? I pressure tested the car and there were not any leaks on the initial log. I don't think there was any heat soak either as this was not back to back pulls. Do I need to drill holes in the airbox to allow less pressure drop? WGDC seems to be OK as well.
If anyone is interested in taking a peek here are the logs:
Initial: https://drive.google.com/open?id=0B6...DVLNzQwWWcwd2s
Revised: https://drive.google.com/open?id=0B6...mh3VFdieW51UE0
