Results 1 to 11 of 11
    Sep 15 2016
    Quebec
    S4 Avant imola 6 spd Tial 605
    Hi guys im an Audi fan from Canada and im looking to sell my ride. So here's the description:
    2001 Audi S4 Avant
    CLEAN TITLES
    Imola Yellow 6 Speeds, Alcantara interior with aluminium trims
    130 miles
    Enigne/Drivetrain
    TIAL 605 with EPL fuelling
    ER Intercoolers with carbon fiber shrouds
    Tial silicone hoses
    Samco throttle body boot
    APR diverter valves
    034 catless downpipes
    Neuspeed complete exhaust
    AWE Twin 1
    Rs4 intake
    4" air intake
    Bosch fuel pump
    Aux engine oil cooler
    Spec Stage 3+ Clutch
    JHM short shifter with linkage
    JHM trans rebuilt kit
    APR snub mount with cage
    034 street line engine mounts
    RS4 transmission mounts
    Apikol blue diff mount
    Apikol blue diff carrier bushings
    Low temp thermo switch
    R8 coilpacks
    Turbo timer
    New fuel pressure regulator
    New fluid (power sterring, engine, prestone, a/c, diff, trans, etc)
    A/C is still working
    Tuned by EPL Labs
    Brakes/Wheels/Suspension
    Rotiform Nue 19x8.5 square
    225/35zr19 tires
    ECS Tuning spacer
    Porsche 911 6 pistons brakes in front
    Rs4 rear brake conversion
    stud conversion with slotted disk
    ST coilovers
    Hotchkis & Neuspeed sway bars
    034 full ajustable control arms
    Exterior
    Oem Rs4 front grille
    Windows freshly tinted
    The interior is in mint condition seats are perfect, everything is working
    Still got every bills from what have been done to it. There is over 40 k$ just in parts so my price is fair
    17.000$ with Mercedes Alphards
    16.500$ with Rotiform nue
    16.000$ with oem s4 b7 18" rims
    The car wil be in OCMD from 26/09 to 03/10
    Veteran Member Three Rings SliverJay's Avatar
    May 03 2013
    TX
    This could be the one, if only it was closer. Glws
    Need a B7 Nogaro avant.
    Veteran Member Three Rings avant1987's Avatar
    Jun 06 2016
    PA
    Beautiful avant.
    Projects
    2001 Nogaro S4 Avant 6-speed - RS4 Widebody Conversion
    1995 Audi 90 Sport Quattro 6-speed
    Sep 15 2016
    Quebec
    Distance ain't a problem if you are serious we could work something out. Let me know
    Established Member Two Rings dwbunks's Avatar
    Jun 24 2014
    Ottawa
    Whereabouts in Quebec? I'm living in Ottawa now.
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    605 Imola Avant . Priced well too, you won't have problems selling it, but you will experience withdrawal symptoms. GLWS
    Sep 15 2016
    Quebec
    Dwbunks, im in Quebec City
    Sep 15 2016
    Quebec
    I figure out that i'll have more chances to sell it in a place like here where people knows what it is and how much it worth
    Sep 15 2016
    Quebec
    Bumppp!
    Thanks guys for the good comments
    Sep 15 2016
    Quebec
    Bumppp
    Deactivated Four Rings derek2079's Avatar
    Aug 02 2004
    UT
    If I had the money....
