Results 1 to 13 of 13
    Established Member Two Rings daniel B6 1.8t's Avatar
    May 31 2016
    OC, CA
    What do i replace here?
    May 31 2016
    OC, CA
    Here is a better view.
    Mar 02 2009
    State of Confusion
    I can't see the pics
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    You replace the empty space with pictures.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    May 31 2016
    OC, CA
    Yea just saw that sorry working on it
    May 31 2016
    OC, CA
    - - - Updated - - -
    for some reason iam seein it good here...let me know if isnt up still
    Senior Member Two Rings G-Ride's Avatar
    Dec 16 2008
    Imola 2003 A4 1.8TQ 5spd
    Melbourne Australia
    Pretty poor pic. Are you trying to point out a leak with the coolant feed to the turbo?
    Imola Yellow '03 A4 Quattro 1.8T 5 Speed
    :: Motoza Performance Tuned on e85 ::
    : Frankenturbo F21-L : Bosch EV14 750cc Injectors : 3" MAF : Milltek Turbo Back Exhaust : AudiSport Suspection : ER FMIC : Sachs RE Clutch : TyrolSport Brake Kit : StopTech & Ferodo DS2500 : Goodridge SS Lines : Forge 008 : 034 SD Engine & Trans Mounts : Apikol Snub & Rear Diff Mount : Podi & VEI Digital Boost Gauge :
    May 31 2016
    OC, CA
    yea that leak is coolant?
    - - - Updated - - -
    yes sorry for poor quality
    Dec 16 2008
    Melbourne Australia
    Quote Originally Posted by daniel B6 1.8t View Post
    - - - Updated - - -
    Can you get a better shot of it? If its coming from the top line its coolant, if its coming from the bottom line it's oil.
    See if you can tighten those down a touch and spray it off with some de-greaser or brake cleaner. If that doesn't fix it, then it might be the brass washers under the fittings that need to be replaced.
    May 31 2016
    OC, CA
    i will check those tomorrow morning its night over here and i have my 2nd job i couple mins. Thanks i will update to verify if either coolant or oil
    Apr 07 2011
    Here ya go. Looks like oil. Try and tighten it down like G-Ride mentioned.
    May 31 2016
    OC, CA
    oh damn nicee thanks customa4... yea Gride was oil... but good thing i ordered new copper crush washers just in case
