Results 1 to 20 of 20
    Veteran Member Three Rings VNA4's Avatar
    Jun 20 2015
    San Jose
    Carbon Cleaning - Cost ?
    Hi all,
    I'm about to get a carbon cleaning performed at a shop for my car which currently has 65K. I have few questions:
    1- Does the fuel injection throttle Body Mounting Gasket need to be replaced?
    2- How much does this job usually run for?
    Thanks all
    S4 B8.5 2014
    KW H.A.S. / EuroCode ÜSS Adjustable Sway Bar / AWE Touring Diamond Black / 034 Stage 2+ / DP 187mm / APR Stage II Carbon Back Pipe
    20 x 10 et35 StanceWheels SF01 [PowderCoated Diamond Black]
    SOLD
    AUDI A4 B8 Premium Plus Sport:
    CTS k04/ APR k04 File / AWE Quad exhaust / FMIC: TR8
    VIP VRC 13 : 19X9.5 / Tires: 255/35/19 / Solo werks Coilovers / OE S4 Front Brake Upgrade Kit
    Veteran Member Three Rings redavant's Avatar
    Jun 17 2014
    California - Bay Area
    I had it done on my previous car - '08 RS4. It was a big job and I didn't do it at Audi dealer. I opted for a great mechanic in SF. He is the only one I take my car to. The carbon cleanup on a V8 was about $1200.
    I assume that on a 4 cylinder it should be significantly less unless there is a lot of build-up.
    Don't know about your 1st q.
    Misano Red 2011 B8 A4 Avant S-Line Prestige
    My Build | AvantGarde M510 265/30/19 | RS4 grill | Euro Tail Lights | RS6 Steering Wheel | S-Tronic shifter |
    Veteran Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2019 Audi S4, 2017 Acura MDX
    Woburn, Ma
    Quote Originally Posted by redavant View Post
    I have a question, how the hell do you go go from
    An rs4 to an A4 and smell at night?
    Pedal Responce first responder.
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Quote Originally Posted by 4ringnut View Post
    Probably uses those breathe-right strips.
    Ever tried those things? They're amazing.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Quote Originally Posted by lettuce View Post
    They discontinued the advanced ones tho... Springs for your nose!...
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Jun 17 2014
    Gents... once an Avant lover is always an Avant lover! Miss the MT and power but have my eye on an RS6 Avant... one day I'll bring it over :-)
    Jun 17 2014
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Love that color matched roof box, it might not have the power of the RS4, but it's sure got style! I'm with you on the avant sentiment.
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
    Jun 17 2014
    Quote Originally Posted by avantagg View Post
    thanks brother! :)
    Jun 17 2014
    Just for the fun of it... here's my former beast :)
    Aug 04 2010
    Queenz/Westchester
    Dammit.... I just jizzed all over myself
    Jun 20 2015
    San Jose
    Anyone know if the fuel injection throttle body mounting gasket needs to be replaced? Or its not necessary
    S4 B8.5 2014
    SOLD
    Sep 09 2010
    Destin, FL
    Sploosh
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    ive received quotes from 600-1k for a carbon cleaning for the b8 a4. the more expensive ones did walnut shell blasting in addition to the chemicals and scraping...
    Feb 08 2013
    2019 Cayman GTS, 2016 Forester XT, 2013 S5, 2011 A4 avanti, 2004 TSX
    My local Audi dealer offer (non- walnut shell blasting) carbon cleanup for $300Cdn. Is it still a useful step? Or should I just go for walnut blast? My A4 is 95000km now and didn't feel anything wrong at this moment.
    2019 718 Cayman GTS 6MT
    2016 Subaru Dark Grey Forester XT touring
    2013 Audi Phantom Black S5 6MT Sport Diff, 20" BBS CH-R, Navi, B&O, PSS10, AK, EC sway, Alcon BBK, RS grille & Ecode
    2011 Audi Deep Sea Blue A4 Avant prestige, 19" OEM Ti rotors, PSS10, AK, sway, RS style grille + rear spoiler, Votrex diffusor
    2004 Acura Premium White TSX 6MT
    Senior Member Two Rings shellraider's Avatar
    Dec 03 2015
    North Dakota
    Gorgeous, yep, someday... the RS6 or RS4 avants will make it stateside. For now though, I love my wagon.
    2012 Monsoon B8 A4 Avant S-Line Prestige Package Black Optic : KO4, OEM Gauge Conversion, OEM Facelift LED Brake lights, OEM RS Interior Door handles, Full Engine Rebuild IE, Solid pipe, ECS intercooler, Porsche brake kit
    Dec 03 2015
    North Dakota
    Quote Originally Posted by VNA4 View Post
    Hi all,
    Thanks all
    Sorry your post got a little derailed, Just drooling a bit. As far as the carbon cleanup I have been quoted from 500-1100. I don't know for sure if the gasket needs replacing but I think it is relatively inexpensive to do since you are in there its a good piece of mind.
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    Quote Originally Posted by ians View Post
    For that cost (especially at a dealer) Im pretty sure its not a true carbon cleaning. (Theyre prob using some BG cleaning nonsense). So def not worth it. It kinda depends on how you drive - for a real carbon cleaning. If you drive a lot of highway Id say youre fine. If you drive a ton of stop and go and idling you might want to consider it.
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
    Feb 08 2013
    Quote Originally Posted by audrobotic View Post
    I just know it is not walnut blasting but no idea what method they going to do. I should consider find another shop for carbon cleaning then.
    Nov 23 2009
    NYC, US
    How do you guys know whether they really did the carbon cleaning? Do they let you stand next to the guy who is the doing the cleaning? Or is there a pic of before and after? I don't think you will notice the difference by driving the car after the cleaning.
