Results 1 to 3 of 3
    Established Member Two Rings CJ_Dubs's Avatar
    Nov 09 2010
    2001.5 B5 S4 - Stage 3 - Casablanca White with Nogaro Alcantara Interior. Priced to Sell - No Longer Available
    Up for sale is my 2001.5 Stage 3 S4.
    Casablanca White with Nogaro Alcantara swapped Interior. Freshly Re-sprayed Front Bumper. All seats are in great condition; Rear seats have hardly been sat in.
    The reason for the low price is that I am looking for a quick sale due to needing a down payment for a house; Car really isn?t a priority anymore.
    I have built and owned this car for 5 years. As of late is has been a dust collector.
    The motor currently has 120k and full Stage 3 (including replacing damn near every seal on the motor) at 96k.
    There are well over 20k in aftermarket parts. Car gets 5k Rotella 5W-30 Oil changes and NGK BKR7E Spark plugs. Current Maintenance includes driver?s side front and rear wheel bearings, Power steering Rack, Rotors and Pads all the way around all done in the last 10K.
    I?ll start with the mod list:
    -Frankenturbo F21?s
    -Old Epic Tuning Group Tune (Never revised, definitely would suggest a remap from a current respectable tuner)
    -Southbend Stage 4 Clutch with Southbend Lightweight Flywheel
    -Fully re-built O1E Transmission with Cryo Treated 1st and 2nd synchros.
    -Bosch EV14 52LB injectors (Need replacing)
    -Bosch 044 High Pressure Fuel Pump
    -Brand new NGK BKR7E?s installed
    -034 Bi-Pipes with Meth Bungs (Powdercoated Wrinkle Black)
    -ProjectB5 1-Piece intake with Hitachi MAF (Could use a new filter)
    -034 Catless 3? Downpipes
    -3? Borla Exhaust
    -AWE Intercoolers (Have CF Shrouds, Just never installed)
    -BREMBO 17Z Big Brake Kit
    -KW V2 Coilovers
    -It has a short shifter installed, Unsure of brand.
    -AWE Center Vent Boost Gauge
    -Aluminum cluster rings
    -Challenge Motorwerks Weighted Shift Knob
    -Carbon Fiber 3M wrapped Interior Trim
    -18X9.5 Konig Wheels (forgot the model currently), 5x114.5 (Wobble Bolts Included)
    -225/40/18 Nitto Neogen tires.
    -RS4 Grille
    -Euro Trunk
    -Car has brand new Fog Lights just haven?t installed them yet.
    On to the problem areas:
    -Needs a clutch. I currently have a brand new Clutchmasters FX400 6-Puck that I just don?t have the time or desire to install. Can be negotiated with sale price.
    -Car currently has a CEL for Fuel Trim Lean. Under WOT the car spits and sputters, but idles and drives smooth under light load. 99.9% sure the Injectors need to be replaced. They were used when I installed them. Changed plugs, not the issue.
    -Brake Pad Sensor Light is on, Sensor was bypassed years ago, Wiring most likely came undone.
    -No A/C. Was in the process of doing a full delete. Condenser and Compressor still installed, I have the rest of the lines set aside.
    -No Filler Plate.
    -Short Shifter could probably use a proper alignment, Adjusted it by feel, Kind of gotten used to it.
    -Couple Tree Sap spots on the trunk lid, Just haven?t taken the time to get it off.
    Car also will come with:
    -Car cover
    -Stock Brake Calipers
    -AWE Carbon Fiber Intercooler Shrouds
    -Tons of Stock B5 Parts if interested.
    Negotiations:
    VERY FIRM on my price. I am motivated to sell, But not to get nickeled and dimed. I know what the car is worth and the price reflects as much of a hit as I am willing to take: Car is priced well below market value and worth a ton more if parted out.
    $6,500 ? Comes with Wheels and Clutchmasters FX400
    $5,500 ? Everything and Bring your own wheels.
    List Date: 9/21/2016
    For more info, click here to view the original listing: 2001.5 B5 S4 - Stage 3 - Casablanca White with Nogaro Alcantara Interior. Priced to Sell
    This item is no longer available.
    Jun 07 2007
    Livermore, CA
    Awesome, until it's noted the car is from NY :) Ya I think this should go fast for those that don't care or live on the East coast.. Not very many Casa's coming up for sale..
    GLWS!!
    May 07 2010
    Long Island, NY
    Is this car seriously already sold? If not I'm very interested and in NY. You have pm
