Results 1 to 7 of 7
    Aug 15 2016
    SJ/CA
    Muffler delete on A7
    So just did a Muffler delete on A7 (C7) it sounds good at cold start and normal drive around the town. However the drone is bad at 2k-2800 Rpm.
    Is this usual? Wondering if Resonator delete will have the same impact?
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    Quote Originally Posted by bmre90 View Post
    center muffler?
    stiraght or X-pipe?
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    Aug 15 2016
    SJ/CA
    just the Muffler next to exhaust tips.
    No X pipe.
    I dont how loud it will get if i go with X pipe now that i have deleted the Mufflers itself.
    Aug 15 2016
    SJ/CA
    To be more clear, all i did is straight pipe AFTER the resonator and single exhaust tip.
    Coming from BMW, this is a pretty famous mod on M series, so i decided to just delete the mufflers rather than resonator.
    Veteran Member Three Rings 4Chio's Avatar
    Mar 14 2005
    STL
    well you should have done the opposite !! delete the res not the mufflers ! that has to be loud
    2018 S6 Prestige ,sport, JB4
    2014 991 Cab C4S
    2018 S4 Prestige
    2017 Q7 Prestige
    (sold)
    2016 S3 Monsoon Gray Prestige | Sport seats| 19's W/ mag ride| Milltek Res valve
    2013 X5 M, 08 A6 4.2 Sline, 08 :.R32 ,07 S4 White/Black, 04 S4 6MT,
    Aug 15 2016
    SJ/CA
    i guess i learned that hard way.
    does anyone know if active noise cancellation is also based on the rear mufflers. i feel there is more noise in cabin after this :=(
    Senior Member Three Rings 2wookies's Avatar
    Jun 03 2016
    Omaha NE
    God this sounds like a bad day! Just order the AWE setup and call it a day, or put the old stuff back on.
